Intel® MPI Library
Bugged MPICH 3.3b2 used in Parallel Studio 2019 initial release
EricChamberland
Hi, I just realized that the Parallel Studio 2019 initial release is using MPICH 3.3b2 which is a buggy release as reported here: https://lists.mpich.org/pipermail/discuss/2018-April/005447.html I confirm that the tag upper limit initialization is not fixed in this release (see mpich commit: c597c8d79deea22) and is a problem for all PETSc users. What a bad choice for an official release!!! Please consider releasing with MPICH 3.3b3 instead, or no MPI at all! Eric
James_T_Intel
Eric,
We actually don't include MPICH in Intel® Parallel Studio XE.  We include our own implementation, Intel® MPI Library.  Can you please confirm which MPI you are using?
mpirun -v
Our engineering team has implemented a fix for the bug mentioned above, and expects you could be encountering a different problem.
James_T_Intel
Can you also provide the exact configuration and tests which are failing?  Our engineering team tested with the problem test reported in the mpich-maillist and did not get any errors.
$ mpirun -n 2 src/ksp/ksp/examples/tutorials/ex2
Norm of error 0.000411674 iterations 7
$ I_MPI_FABRICS=ofi mpirun -n 2 src/ksp/ksp/examples/tutorials/ex2
EricChamberland
Ok, give me some time to re-install everything since I completely wiped out everything...
I may get back to you only on oct. 15 since I am out next week...
Eric
EricChamberland
BTW,
please help me understand:
Why the mpi.h file distributed is the MPICH one?
When trying to identify the MPI flavor at *compile time*, it is impossible! (see https://software.intel.com/en-us/forums/intel-clusters-and-hpc-technology/topic/797705)
Thanks!
Eric
James_T_Intel
I'm checking with our engineering team regarding the information in your other thread.
EricChamberland
Ok, I reinstalled everything...
to confirm the version I used:
which mpirun /opt/intel/compilers_and_libraries_2019.0.117/linux/mpi/intel64/bin/mpirun
-bash-4.4$ mpirun -v
[mpiexec@thorin] main (../../../../../src/pm/hydra2/mpiexec/mpiexec.c:1645): assert (pg->total_proc_count * sizeof(int)) failed
-bash-4.4$ mpirun -V
Intel(R) MPI Library for Linux* OS, Version 2019 Build 20180829 (id: 15f5d6c0c) Copyright 2003-2018, Intel Corporation.
Also, I tried the PETSc example, and it works! :/
So my problem is different then the one I thinked...
I have an error returned by a "simple" MPI_Isend. I am trying to produce a MWE to give it to you.
Eric
EricChamberland
Ok,
this is still a "tag" bug.
I have simple MWE attached, which gives the following explicit error:
Abort(67744516) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Irecv: Invalid tag, error stack:
PMPI_Irecv(156): MPI_Irecv(buf=0x7ffff2268900, count=10, MPI_INT, src=0, tag=123454321, MPI_COMM_WORLD, request=0x7ffff2268974) failed
PMPI_Irecv(100): Invalid tag, value is 123454321
If you compile the attached example with OpenMPI or MPICH, it works!
Hope this help!
Eric
EricChamberland
Doh!
Just realized that MPI standard tag limit is 32767... :/
But it is not activated for other MPI flavours..
So it is *my* error, sorry!
Eric
James_T_Intel
No worries.  Since this is resolved, I'm going to go ahead and close this thread.
