Intel® MPI Library
2286 Discussions
Difference between mpicc and mpiicc
Fuli_F_
I write a simple mpi program as follow:
#include "mpi.h"
#include <stdio.h>
#include <math.h>
void main(argc,argv)
int argc;
char *argv[];
    int myid,numprocs;
    int namelen;
    char pro_name[MPI_MAX_PROCESSOR_NAME];
    MPI_Init(&argc,&argv);
    MPI_Comm_rank(MPI_COMM_WORLD,&myid);
    MPI_Comm_size(MPI_COMM_WORLD,&numprocs);
    MPI_Get_processor_name(pro_name,&namelen);
    printf("Process %d of %d on %s\n",myid,numprocs,pro_name);
    MPI_Finalize();
When I compile it with "mpicc -o xxx xxx.c" and run it with "mpirun -np 8 ./xxx", it rightly creates 8 processes. But when I compile it with "mpiicc -o xxx xxx.c" and run with the same order as above, it only creates 1 process. I want to know what's the difference between the mpicc and mpiicc. Is it caused by some faults made during my installment? And how can I fix it? By the way, I install the impi and compiler of intel by installing the intel cluster studio (l_ics_2013.1.039_intel64).
Here is the result:
[root@localhost test]# mpicc -o mpitest mpi-test.c
[root@localhost test]# mpirun -np 8 ./mpitest
Process 3 of 8 on localhost.localdomain
Process 4 of 8 on localhost.localdomain
Process 5 of 8 on localhost.localdomain
Process 6 of 8 on localhost.localdomain
Process 7 of 8 on localhost.localdomain
Process 0 of 8 on localhost.localdomain
Process 1 of 8 on localhost.localdomain
Process 2 of 8 on localhost.localdomain
[root@localhost test]# mpiicc -o mpitest mpi-test.c
Process 0 of 1 on localhost.localdomain
James_T_Intel
The difference in the two is that mpiicc uses icc, and mpicc allows you to select the compiler, defaulting to gcc.  But there's definitely something wrong here.  Please run the following commands and attach the output.txt file:
[plain]echo "***mpicc show" > output.txt
mpicc -show -o gtest mpi-test.c >> output.txt
echo "***mpiicc show" >> output.txt
mpiicc -show -o itest mpi-test.c >> output.txt
mpicc -o gtest mpi-test.c
mpiicc -o itest mpi-test.c
echo "***ldd gtest" >> output.txt
ldd gtest >> output.txt
echo "***ldd itest" >> output.txt
ldd itest >> output.txt
echo "***runtest gtest" >> output.txt
mpirun -n 8 -genv I_MPI_DEBUG 5 -verbose ./gtest 2>&1 >> output.txt
echo "***runtest itest" >> output.txt
mpirun -n 8 -genv I_MPI_DEBUG 5 -verbose ./itest 2>&1 >> output.txt[/plain]
My guess is that there's something wrong in the configuration, and one of these should show the problem.
James_T_Intel
Fuli_F_
Thanks for your reply! I run these commends here is the result:
***mpicc show
icc -o gtest mpi-test.c -I/usr/local/include -pthread -Wl,-rpath -Wl,/usr/local/lib -Wl,--enable-new-dtags -L/usr/local/lib -lmpi
***mpiicc show
icc -o itest mpi-test.c -I/opt/intel//impi/4.1.1.036/intel64/include -L/opt/intel//impi/4.1.1.036/intel64/lib -Xlinker --enable-new-dtags -Xlinker -rpath -Xlinker /opt/intel//impi/4.1.1.036/intel64/lib -Xlinker -rpath -Xlinker /opt/intel/mpi-rt/4.1 -lmpigf -lmpi -lmpigi -ldl -lrt -lpthread
***ldd gtest
        linux-vdso.so.1 =>  (0x00007fffeddff000)
        libmpi.so.1 => /usr/local/lib/libmpi.so.1 (0x00007fd0ac7a8000)
        libm.so.6 => /lib64/libm.so.6 (0x0000003fc3e00000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x0000003fcfe00000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x0000003fc4600000)
        libc.so.6 => /lib64/libc.so.6 (0x0000003fc4200000)
        libdl.so.2 => /lib64/libdl.so.2 (0x0000003fc4a00000)
        libopen-rte.so.7 => /usr/local/lib/libopen-rte.so.7 (0x00007fd0ac4fb000)
        libopen-pal.so.6 => /usr/local/lib/libopen-pal.so.6 (0x00007fd0ac1f5000)
        librt.so.1 => /lib64/librt.so.1 (0x0000003fc5200000)
        libnsl.so.1 => /lib64/libnsl.so.1 (0x0000003fd4e00000)
        libutil.so.1 => /lib64/libutil.so.1 (0x0000003fd3e00000)
        libimf.so => /opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libimf.so (0x00007fd0abd36000)
        libsvml.so => /opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libsvml.so (0x00007fd0ab2da000)
        libirng.so => /opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libirng.so (0x00007fd0ab0d3000)
        libintlc.so.5 => /opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libintlc.so.5 (0x00007fd0aae7d000)
        /lib64/ld-linux-x86-64.so.2 (0x0000003fc3a00000)
***ldd itest
        linux-vdso.so.1 =>  (0x00007fff9a7ff000)
        libmpigf.so.4 => /opt/intel//impi/4.1.1.036/intel64/lib/libmpigf.so.4 (0x00007f6207515000)
        libmpi.so.4 => /opt/intel//impi/4.1.1.036/intel64/lib/libmpi.so.4 (0x00007f6206eb5000)
***runtest gtest
***runtest itest
Unfortunately, I got the error "mpirun: Error: unknown option "-genv" Type 'mpirun --help' for usage.", when I run this commend "mpirun -n 8 -genv I_MPI_DEBUG 5 -verbose ./itest 2>&1 >> output.txt"
Fuli_F_
Hi,James:
Thanks for your reply. I run your commands and here are the results:
***mpicc show
***mpiicc show
***ldd gtest
***ldd itest
"output.txt" 35L, 2300C                                                  1,1          椤剁        2
***runtest gtest
***runtest itest
Unfortunately, I got this error "mpirun: Error: unknown option "-genv" Type 'mpirun --help' for usage.", when I run "mpirun -n 8 -genv I_MPI_DEBUG 5 -verbose ./gtest 2>&1 >> output.txt"
By the way, the ICS is installed on an alone server, so when it asks me to create the "amchine.LINUX" file, I carelessly write one line isn't same with the result of command "hostname".
James_T_Intel
First, correct the machine file.  The host name listed should match the output from hostname.
Second, what is the output from
[plain]which mpirun[/plain]
Fuli_F_
which mpirun
Thank you very much!The cause maybe I use Intel compiler mpiicc and run it with the unmatched openmpi mpirun. Because another guy in our team installed the openmpi on our server, but didn't inform us. the mpicc and mpirun is firstly found at /usr/local/bin.
James_T_Intel
To avoid this in the future, simply source the environment variable script provided in the installation before using the Intel® MPI Library.  This will set the paths correctly as well as setting I_MPI_ROOT.
TimP
It's still highly desirable to install various MPI builds in their specific directories, e.g. /opt/openmpi_16/  so they don't get mixed in at build or run time unless the specific PATH and LD_LIBRARY_PATH have been set; possibly by module load   http://modules.sourceforge.net
