Intel® MPI Library
2288 Discussions
Does icpx has backward compatibility for icpc
hevgo
I am using Intel Parallel Studio XE for years, and since Intel Parallel Studio XE do not offer student license, I move to oneAPI.
I found no icpc support in oneAPI. Instead, the compiler for C++ is icpx. But when I use icpx on my old code it returns thousands of errors, (was fine with icpc).
So, does icpx has backward compatibility for icpc. or do I need to add some flags?
Hevgo.
AbhishekD_Intel
Please try installing Intel oneAPI HPC toolkit you will get icpc inside compiler. Hope this will solve your problem.
Warm Regards,
Abhishek
AbhishekD_Intel
Yes, ICPX is almost compatible with ICPC. But there are some small changes in the functionality and behavior of ICPX as compare to ICC. Please refer to the below porting guide for more details.
https://software.intel.com/content/www/us/en/develop/articles/porting-guide-for-icc-users-to-dpcpp-or-icx.html
Hope it will help you to resolve your issue.
Warm Regards,
Abhishek
hevgo
Hi Abhishek,
Thank you so much for the reply. I really appreciate it.
I have read the website and tried using "icx" or "icpx" to replace "icpc" in my makefile. But both of them return so many errors, while the makefile returns no error with "icpc". Most of the errors make no sense including on parameter pack, expression pack, OpenMP SIMD, OpenMP nontemporal.
Is there any way that I can directly use "icpc" under OneAPI?
Bests,
Yuxuan
AbhishekD_Intel
Warm Regards,
Abhishek
hevgo
Hi Abhishek,
That is really good news to me.
I have installed Intel oneAPI HPC Toolkit. But when I run my makefile with "icpc" it returns the following.
icpc -g -std=c++17 -fopenmp -fopenmp-targets=spir64 -fno-alias -restrict -Wall -Wextra -wd1011 -O3 -march=native -qopt-zmm-usage=high -qopt-report=5 -qopt-report-phase=all -I./src -I./test  -o ./run ./main.cpp -D PROC_COUNT=$(grep -c ^processor /proc/cpuinfo)
Error: Product support for your (Comp-CL) license has expired.
License file(s) used were (in this order):
** 1. /home/yuxuan/intel/compilers_and_libraries_2019.5.281/linux/licenses
** 2. /opt/intel/licenses/l_RBHGGPWW.lic
** 3. /opt/intel/licenses/l_THKJBFS8.lic
** 4. /home/yuxuan/intel/licenses/l_RMPJRNBW.lic
** 5. /home/yuxuan/intel/licenses/l_THKJBFS8.lic
** 6. /home/yuxuan/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/../../Licenses
** 7. /home/yuxuan/Licenses
** 8. /Users/Shared/Library/Application Support/Intel/Licenses
** 9. /home/yuxuan/intel/compilers_and_libraries_2019.5.281/linux/bin/intel64/*.lic
Please refer https://software.intel.com/en-us/faq/purchasing-renewing-upgrading#support-expiration for more information..
icpc: error #10052: could not checkout FLEXlm license
Makefile:10: recipe for target 'all' failed
make: *** [all] Error 1
I believe this is because my license for Intel Parallel Studio has expired.
Is there any way to bypass this license checking, or do I need to uninstall my old Parallel Studio XE?
Yuxuan
hevgo
NVM, It works! Thank you so much.
AbhishekD_Intel
Thanks for the confirmation, glad to know that your issue is resolved. We will no longer monitor this thread.
Please post a new thread if you have any issues.
Warm Regards,
Abhishek
