Intel® MPI Library
2286 Discussions
Does "Intel MPI library" contain 'MPI Datatype Bool' ???
bugslayer
Hi all.
I'm trying to use Intel MPI library (evaluation version) instead of LAM/MPI.
But I couldn't find Datatype BOOL in namespace MPI (c++ version) - MPI::BOOL.
(LAM/MPI contains that type)
Other types(char, byte, int, ...) exist in /include64/mpicxx.h, but there's no entry for bool.
How can I use that ?
JH
TimP
Quoting - bugslayer
The standards support level specified for iMPI 4 (currently available to you as a beta) implies (I think) that this feature should be there. If not, you might file a bug report prior to the end of the beta test.
Gergana_S_Intel
Hi JH,
As Tim points out, the BOOL data type is available with Intel MPI Library 4.0 Beta. You can register for and download the beta at www.intel.com/go/mpi.
Let us know if you hit any problems.
~Gergana
bugslayer
Thanks for your answer.
But there's problem on the link. I can't register for it.
Error page shows me 'critical system error.' :<
JH
Gergana_S_Intel
Quoting - bugslayer
Hi JH,
I just registered for the beta without any problems. Can you make sure to delete your cookies and restart your browser?
Here is also a direct link to register for the Intel MPI Library 4.0 Beta for Linux*.
~Gergana
