Intel® MPI Library
2279 Discussions
Enable the ASYNC progress thread on HPC having infiniband.
Mohit9638
Respected sir/madam,
Please help me to enable the async thread for Intel MPI on HPC having interconnect as Infiniband.
Mohit Kumar
SantoshY_Intel
Below are the steps to enable asynchronous progress control:
1. To specify the configuration, source the vars.[c]sh script with the -i_mpi_library_kind environment variable.
Example
source /opt/intel/oneAPI/2021.4.0.3347/setvars.sh
source /opt/intel/oneAPI/2021.4.0.3347/mpi/2021.4.0/env/vars.sh -i_mpi_library_kind=release
For more information, refer to the below link:
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/running-applications/selecting-a-library-configuration.html
(or) You can just export the I_MPI_LIBRARY_KIND environment variable which is equivalent to step 1 mentioned above.
Example:
$ export I_MPI_LIBRARY_KIND=release
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-reference-linux/top/environment-variable-reference/other-environment-variables.html
2. Compile the MPI code using the below command:
mpiicc sample.c
3. Now, pass 1 to I_MPI_ASYNC_PROGRESS environment variable to enable asynchronous progress control.
I_MPI_ASYNC_PROGRESS=1 mpirun -n 16 ./a.out
https://www.intel.com/content/www/us/en/develop/documentation/mpi-developer-guide-linux/top/additional-supported-features/asynchronous-progress-control.html
I tried the above steps using the Intel MPI 2021.4 on a Linux machine and sharing with you the complete debug log for each step.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues. Thank you!
Santosh
Mohit9638
Hi Santosh,
I have tried your approach but not getting the desired result.
-The time taken by sample code with I_MPI_ASYNC_PROGRESS=0 << time taken by sample code with I_MPI_ASYNC_PROGRESS=1
- I am using HPC having infiniband with Intel Compiler 2020.2.254 version.
Mohit Kumar
SantoshY_Intel
>>"The time taken by sample code with I_MPI_ASYNC_PROGRESS=0 << time taken by sample code with I_MPI_ASYNC_PROGRESS=1"
We can see that you have raised a similar issue in the Intel community forum. So, please keep track of your issue for updates using the below link:
https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/Intel-MPI-Compiler-2018-5-274/m-p/1365509#M9252
>>"I have tried your approach but not getting the desired result."
Since your initial query has been resolved, can we go ahead and close this thread?
Thanks & Regards,
Santosh
SantoshY_Intel
We haven't heard back from you. Since your initial query has been resolved, can we go ahead and close this thread?
Thanks & Regards,
Santosh
SantoshY_Intel
Since your initial query is resolved, we are closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Santosh
