Intel® MPI Library
2302 Discussions
Asynchronous progress slows down my program
manasi-t24
I am running PETSc code on our institute's supercomputer Pravega. I have compiled my PETSc code after loading the following modules and sourcing mpivars.sh:
  1. module load spack
  2. . /home-ext/apps/spack/share/spack/setup-env.sh
  3. spack load gcc
  4. module load compiler/intel/2020.4.304
  5. source /opt/ohpc/pub/compiler/intel/2020_4/compilers_and_libraries_2020.4.304/linux/mpi/intel64/bin/mpivars.sh release_mt
After compilation, I am running the code with the following script where export I_MPI_ASYNC_PROGRESS=0:
#!/bin/bash
#SBATCH -N 2
#SBATCH --ntasks-per-node=48
#SBATCH --exclusive
#SBATCH --time=00:03:00
#SBATCH --job-name=ex2
#SBATCH --error=ex2.e%J
#SBATCH --output=ex2.o%J
##SBATCH --partition=standard
module load spack
spack load gcc
# // Below are Intel MPI specific settings //
#export I_MPI_FABRICS=ofi:ofi
#export I_MPI_DEBUG=10
#export I_MPI_ASYNC_PROGRESS_THREADS=1
cd $SLURM_SUBMIT_DIR
nprocs=96
ulimit -aH
ulimit -c unlimited
ulimit -s unlimited
mpiexec.hydra -n $nprocs ./ex2 -m 80 -n 80 -ksp_monitor_short -ksp_type pipecg2 -pc_type jacobi
*************end of script**************
Time taken by the above job to run is 0.280063 sec.
I am also running the code with the following script where export I_MPI_ASYNC_PROGRESS=1
#!/bin/bash
#SBATCH -N 2
#SBATCH --exclusive
module load spack
spack load gcc
nprocs=96
ulimit -aH
ulimit -c unlimited
ulimit -s unlimited
Time taken by the above job to run is 22.659463 sec.
I observe that my code takes much more time to run when I use I_MPI_ASYNC_PROGRESS=1 than when I use I_MPI_ASYNC_PROGRESS=0. Why is this happening? I read this blog (https://techdecoded.intel.io/resources/hiding-communication-latency-using-mpi-3-non-blocking-collectives/?elq_cid=9262301_ts1646820353975&erpm_id=11789269_ts1646820353975#gs.seb071) but could not quite understand what needs to be done in order to bring performance improvement. Please help.
Manasi
HemanthCH_Intel
>>" I have compiled my PETSc code after loading the following modules and sourcing mpivars.sh:"
Could you please provide the steps that you have followed to compile the PETsc code?
>>"mpiexec.hydra -n $nprocs ./ex2 -m 80 -n 80 -ksp_monitor_short -ksp_type pipecg2 -pc_type jacobi"
Could you please provide us the path to the "ex2" binary from the PETsc directory?
Could you please provide the OS details?
Thanks & Regards,
Hemanth.
manasi-t24
I downloaded the PETSc repository from gitlab using:
git clone -b release https://gitlab.com/petsc/petsc.git petsc-cpu-intel
After loading the following modules:
  3. spack load gcc
I configured the PETSc code with:
./configure --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --download-make --download-fblaslapack=1
And then I compiled it with:
make PETSC_DIR=/scratch/cdsmanas/petsc-cpu-intel PETSC_ARCH=arch-linux-c-debug all
The directory for ex2 is:
<petsc directory>/src/ksp/ksp/tutorials/ex2
OS and its version:
[cdsmanas@login10 tutorials]$ cat /etc/os-release
NAME="CentOS Linux"
VERSION="7 (Core)"
ID="centos"
ID_LIKE="rhel fedora"
VERSION_ID="7"
PRETTY_NAME="CentOS Linux 7 (Core)"
ANSI_COLOR="0;31"
CPE_NAME="cpe:/o:centos:centos:7"
HOME_URL="https://www.centos.org/"
BUG_REPORT_URL="https://bugs.centos.org/"
CENTOS_MANTISBT_PROJECT="CentOS-7"
CENTOS_MANTISBT_PROJECT_VERSION="7"
REDHAT_SUPPORT_PRODUCT="centos"
REDHAT_SUPPORT_PRODUCT_VERSION="7"
Manasi
HemanthCH_Intel
As we have worked with you internally and your issue has been resolved, we are closing this thread. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth.
