Intel® MPI Library
2285 Discussions
Error from mpiexec - readv failed - errno 9 (Bad file descriptor)
Ramesh
I am running an MPI application using IntelMPI. I could run this application using 1process successfully. While running it with more than 1process I am getting the following error.
1: Fatal error in PMPI_Waitall: Other MPI error, error stack:
1: PMPI_Waitall(284)..................: MPI_Waitall(count=1, req_array=0x124fb350, status_array=0x1) failed
1: MPIR_Waitall_impl(121).............:
1: MPIDI_CH3I_Progress(720)...........:
1: MPID_nem_lmt_vmsplice_progress(327):
1: do_readv(151)......................: readv failed - errno 9 (Bad file descriptor)
Kindly help me to resolve this issue.
Ramesh----
James_T_Intel
Hi Ramesh,
Can you provide a reproducer code?  Do you have Intel® Trace Analyzer and Collector installed?  If so, please run with -check_mpi to ensure that your MPI calls are correct.
James.
James_T_Intel
Ramesh,
You sent me a private message, but I'm currently unable to get to my private messages, and only have the email notification.  Can you pinpoint the location of the segfault you are seeing?
James.
Ramesh
Hi James,
I resolved the segmentation fault using "-heap-arrays" option. But my program is executing very slowly.
Ramesh
James_T_Intel
Have you used either the Intel® Trace Analyzer and Collector or Intel® VTune™ Amplifier XE on it to pinpoint the problem area?
