Intel® MPI Library
Error while running mpitune utility
srinivasan_G_1
Hi, we have 8 nodes cluster with each node having xeon 8cores. all the clusters are connected using mellanox infiniband. I have installed intel cluster studio xe 2015. i have been using mpiicc and mpirun for a while. Now i wanted to use mpitune utility using hostfile hosts
node1
node1
node2
node2
node3
node3
i tried to call mpitune from my current directory by
mpitune -hf hosts -odr /home/srinivasan/
mpitune stops by giving this output
25'Nov'15 22:11:38 INF | Starting. Please wait...
25'Nov'15 22:11:38     | MPITune started at  25 November'15 (Wednesday) 16:41:38
25'Nov'15 22:11:38     | MPITune has been started by: srinivasan
25'Nov'15 22:11:38     | Preparing tuner's components...
25'Nov'15 22:11:38     | Initialization of signals handlers...
25'Nov'15 22:11:38     | Start catching signal with code 15 (SIGTERM) ...
25'Nov'15 22:11:38     | Success.
25'Nov'15 22:11:38     | Start catching signal with code 2 (SIGINT) ...
25'Nov'15 22:11:38     | Initialization of signals handlers completed.
25'Nov'15 22:11:38 CER | Can not continue due to error while detecting Intel MPI Library.
25'Nov'15 22:11:38 CER | A critical error has occurred!
Details:
Type  : <type 'exceptions.Exception'>
Value : Can not continue due to error while detecting Intel MPI Library.
25'Nov'15 22:11:38     | Time of work automatic tuning utility is 0h:0m:0s:37ms
25'Nov'15 22:11:38 CER | Error while terminating child processes. Description: 'NoneType' object has no attribute 'DestroyAllChildProcesses'
25'Nov'15 22:11:38 INF | Safe application's termination completed.
I dont know how to rectify this. any suggestions??
Michael_Intel
The Intel MPI library that you are using is quite old, please update to the most recent IMPI 5.1.2 library that you can find on the registrationcenter website.
In your hostfile, you don't need to repeat the host names, the number of cores per node can be provided to mpitune via the -pr parameter.
Please try the following and provide us the output.:
$ cat hosts | uniq > hosts_new
$ mpiicc -o test.x $I_MPI_ROOT/test/test.c
$ mpirun -hostfile ./hosts_new ./test.x
$ mpitune -hf ./hosts_new
Michael
srinivasan_g_
Hi micheal,
 Yes i do know that the library is a bit old but our cluster server here have RHEL 5.4 installed. Only  intel MPI Library 4.1.3.048 is compatable with this. As we dont have any sytem admin here, disturbing the configuration might bcome a problem for me.
Anyways as per the commands you gave, the outputs are as follows (all were executed from root account)
cat: hosts: No such file or directory
$mpiicc -o test.x test.c
warning #13003: message verification failed for: 28003; reverting to internal message
warning #13003: message verification failed for: 28008; reverting to internal message
/tmp/iccgBuRfW.o: In function `main':
test.c:(.text+0x2e): undefined reference to `__intel_new_feature_proc_init'
After executing the above command the test.c file is not there in the location. its missing. before execution it was there in that location. Now its missing. dont know wt happened.
$ ls (Before execution)
test.c test.cpp test.f test.f90
$ ls (After executing mpiicc -o test.x test.c )
In which directory should i run the below commands???
G SRINIVASAN
Michael_Intel
Since the same issue is being discussed in form of an Intel Premier Support (IPS) ticket, I will work on the IPS ticket and update this thread as soon as it is resolved.
Michael
