- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
I've followed the instructions in the 'getting started' file to set up a linux cluster with 4 nodes. Mpdboot works ok as mpdtrace verifies, and my programs compile, but don't run as they should: Taking the testc program as an example, with the command:
mpiexec -n 4 --machinefile ~/mpd.hosts ./testc
I get the output:
Hello world: rank 0 of 1 running on node1
Hello world: rank 0 of 1 running on node2
Hello world: rank 0 of 1 running on node3
Hello world: rank 0 of 1 running on node4
...so while the job is farmed out to the 4 nodes, each node thinks that it's the master, and needs to do the propagation etc. Have I missed something embarassingly obvious here? Any help would really be great!
I get the output:
Enlace copiado
2 Respuestas
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Could you provide some more details, please?
1. Exact mpdboot command
2. Output of "which mpiexec"
2. Debug output of
"mpiexec -genv I_MPI_DEBUG 3 -machinefile ~/mpd.hosts -n 4 ./testc"
Thank you in advance,
- Grigory
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Hi Grigory,
Thanks for the help - it was the 'which mpiexec' that solved the problem: it was referencing /usr/bin and not the intel mpi bin directory. Pretty silly thing not to have found earlier. Thanks again.
Responder
Opciones de temas
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
