Intel® MPI Library
2279 Discussions
How can I explicitly assign rank number to each host?
seongyun_k_
Whenever I run MPI application, it seems rank numbers get different.
Can I fix those MPI rank number affinity?
Mark_L_Intel
   It sounds like MPI Process Pinning is not working? It should. Could you provide your job script and launching mpirun command? Meanwhile, here are defaults settings for Process Pinning:
https://software.intel.com/en-us/node/561772
You can search through the online documentation regarding each of these settings. Of course, please do ask questions as well.
Cheers,
Mark
