Intel® MPI Library
How many processes we can run run HPL on with Intel MPI ?
Nihir_Parikh
If we are using evaluation version of Intel MPI/compiler/MKL (cluster tools) how many cores/processes we can run HPL on?
Nihir_Parikh
hpl.log file when we run hpl on nodes larger than 2880
Gergana_S_Intel
Hey Nihir,
Thanks for getting in touch.  We're done HPL runs with Intel MPI and MKL up to 150K ranks.  At that scale, there's a few things you need to set, some which relate to internal thresholds for the Intel MPI Library, and others are timeout and retry values for the DAPL stack.  Here's a recent set of env settings used to scale out:
export I_MPI_FABRICS=shm:dapl
export I_MPI_DAPL_UD=on
export I_MPI_DAPL_UD_SEND_BUFFER_NUM=4096
export I_MPI_DAPL_UD_RECV_BUFFER_NUM=4096
export I_MPI_DAPL_UD_ACK_SEND_POOL_SIZE=4096
export I_MPI_DAPL_UD_ACK_RECV_POOL_SIZE=4096
export I_MPI_DAPL_UD_RNDV_EP_NUM=2
export I_MPI_DAPL_UD_REQ_EVD_SIZE=2000
export DAPL_UCM_REP_TIME=2000  #  REQUEST timer, waiting for REPLY in millisecs
export DAPL_UCM_RTU_TIME=2000  #  REPLY timer, waiting for RTU in millisecs
export DAPL_UCM_RETRY=10         #  REQUEST and REPLY retries
export DAPL_ACK_RETRY=10         #  IB RC Ack retry count
export DAPL_ACK_TIMER=20       #  IB RC Ack retry timer
Give these a try and let me know how it goes.  I would recommend you ensure you're running the latest dapl package from the OpenFabrics repository.
My colleague Vipin posted a nice overview of running HPL with the Intel tools.  In there, you'll see a link to download Intel's optimized LINPACK benchmark. I hope this helps.
~Gergana
Nihir_Parikh
Gergana,
Thanks for the input, I will try it out and provide you the feedback.
Nihir_Parikh
Gergana,
Can you please help to delete the hpl.log files?
Gergana_S_Intel
Done!
Nihir_Parikh
Gergana,
In our network setup we have two Infiniband leaf switches that is causing this issue. Do you have any recommendation on how to run the HPL in a network that has two leaf switches?
