Intel® MPI Library
How to build connection for two server with infiniband and use intel mpi?
quan_w_
I'm so sorry that i can't find some detail info about using intel mpi to connect two server with infiniband.
I want to know the procedure, and if there is any url about this content?
Please apply me soon, thank you a lot!!!
Mark_L_Intel
Hello Hal,
   If I understand you correctly you would like to setup a cluster with 2 nodes and Infiniband? If that's the case, it is a separate subject from using MPI on such cluster. The cluster setup with Infiniband is a process that normally requires experienced sys admin. It also depends on the hardware and OS installed on the nodes. If you are interested you can start by looking at these links, for example,
https://www.openfabrics.org/
https://pkg-ofed.alioth.debian.org/howto/infiniband-howto-4.html
Mark
Mark_L_Intel
Hello Hal,
Mark
quan_w_
Thank you Mark L.
So sorry reply late.
I have searched the openfabrics before, when i see the introduction of DAPL of intel MPI.
My question is that can i use the IntelMPI in my own c++ program about Infiniband in Windows OS, and help us to connect at least two infiniband nodes.
I have found that almost tutorials tell me that you should input command in shell if you are in Windows OS.
Best wish for you.
xie__karry
Hello quan w,
I wonder if you could tell me the last solution of your problem,because I also can't find some detail info about using intel mpi to connect two server with infiniband. Can you help me ?  I am waiting for your reply, and best wishes for you ~thanks!
