Intel® MPI Library
How to catch MPI exception
Jimmy821
Is there support for MPI::ERRORS_THROW_EXCEPTIONS?
I notice thatany exception is not caught when there is network loss.
Dmitry_K_Intel2
Hi Jimmy,
Please take a look at the example: here
If you do everything correctly but cannot catch an exception that probably means that MPI functon doesn't return error code.
Regards!
Dmitry
Andrey_D_Intel
Could you please clarify what MPI implementation we are talking about? In the Intel MPi Library the MPI::ERRORS_THROW_EXCEPTIONS is supported according to MPI standard specifications.
Andrey
Jimmy821
I am using Intel MPI 4.0. I am running 3 instances of my application on the same computer. To test the exception handling, I forcefully terminate one instance of the application.
However, it appears that the catch block of the 2 other instances are not triggered. I use standard MPI functions such as MPI_TEST, MPI_BCAST, MPI_IRECV, MPI_SEND, MPI_PEEK.
Can I additionally check how to use the I_MPI_TCP_NETMASK flag in a configuration file. I could not include this in any way.
Thanks!
jimmy82
Just a quick update... I realised that I am able to catch an exception due to software error. For example, there is a mis-match between data size.
However, my objective is to catch errors due to network disconnection, or the other nodes hang abruptly. In this case, I read that there is no way because mpiexec does not trap the errors and will proceed to terminate all running processes.
Dmitry_K_Intel2
Hi Jimmy,
Please read clause 5 of the Reference Manual about fault tolerance - might be this is your case (or might be you are talking about check-points).
Mpiexec does not catch errors! Mpiexec aborts an application if one of the processes has been aborted because of error.
Regards!
Dmitry
