Intel® MPI Library
2284 Discussions
How to force CMake to link statically with Intel MPI
DataScientist
Valued Contributor I
All my efforts to achieve this have so far failed. This included setting the proper compiler `-static` flags for Intel ifort and ifx. Is there a way to force static linking of MPI libraries?
TobiasK
TobiasK
@DataScientist
did you try to add -static_mpi ?
DataScientist
Thank you @TobiasK for the suggestion. I have tried adding it to the list of CMake compile/link flags but the compiler returned an error stating the flag is unrecognized. It seems like only the MPI wrapper recognizes the flag. Is this true?
If yes, do you know any way to add this to CMake?
TobiasK
@DataScientist
according to https://cmake.org/cmake/help/latest/module/FindMPI.html
MPI_<lang>_COMPILER_FLAGS
should be used to pass -static_mpi
(https://gitlab.kitware.com/cmake/cmake/-/merge_requests/893)
does that work for you?
DataScientist
Thank you. It seems like this solution worked.
