Intel® MPI Library
2295 Discussions
How to run an MPI program on multiple nodes stored on a network drive ?
ArthurRatz
Dear Collegues, I've got question is it possible to store an MPI program on a network drive and run it on each cluster node ?
Thanks in advance.
Cheers, Arthur.
Artem_R_Intel1
Hi Arthur,
You should just specify the appropriate network path to the MPI application in the command line (the path should be reachable from the all cluster nodes involved into the MPI run), for example (Linux* OS):
mpirun ... /nfs/.../test.exe
or (Windows* OS):
mpiexec ... \\hostname\...\test.exe
Artem_R_Intel1
Hi Arthur,
Yes, mainly it's possible.
ArthurRatz
And could you give an example of how to do it ?
Artem_R_Intel1
Hi Arthur,
or (Windows* OS):
ArthurRatz
Thanks a lot.
