Intel® MPI Library
I_MPI_OFI_PROVIDER vs. I_MPI_OFA_ADAPTER_NAME
Research_A_
The latter has been removed / deprecated in intelmpi 2019.4 which we are currently testing.
We are using environment modules and up to and including intelmpi 2018.3 we had logic in them which set I_MPI_OFA_ADAPTER_NAME to the appropriate interface based on hostname.
I tried using I_MPI_OFI_PROVIDER the same way, and got an error message:
[0] MPI startup(): libfabric version: 1.7.2a-impi
Abort(1094799) on node 26 (rank 26 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(666)......:
MPID_Init(922).............:
MPIDI_NM_mpi_init_hook(719): OFI addrinfo() failed (ofi_init.h:719:MPIDI_NM_mpi_init_hook:No data available)
I guess that this is either the wrong variable or I am not using it correctly.
I believe the syntax is: I_MPI_OFI_PROVIDER=<name>
Looking at the output of I_MPI_OFI_PROVIDER_DUMP I see stuff like:
prov_name: verbs;ofi_rxm
I'd be grateful for any pointers.
Thanks!
Research_A_
I've also just noticed that while I have two interfaces (one configured for ethernet, the other configured for infiniband) the output generated by passing export I_MPI_OFI_PROVIDER_DUMP=1 suggests that only the first interface (mlx5_0 ethernet) is an available provider while I actually want to use the second one (mlx5_1 infiniband).
Research_A_
Having investigated further, I believe that the only provider that supports my hardware is "verbs" (as this is the only one that supports infiniband):
https://software.intel.com/en-us/articles/intel-mpi-library-2019-over-libfabric
However, unless I am reading this incorrectly, it is necessary to be running tcp over the infiniband interface. Is anyone able to confirm?
Thanks!
