Intel® MPI Library
2273 Discussions
I had a problem using intelmpi and slurm
侯玉山
hi,
cpuinfo:
===== Processor composition =====
Processor name : Intel(R) Xeon(R) E5-2650 v2
Packages(sockets) : 2
Cores : 16
Processors(CPUs) : 32
Cores per package : 8
Threads per core : 2
slurm:
Slurm is configured with 30 cpu
Start intelmpi with slurm:
#SBATCH --partition=compute
#SBATCH --nodes=1
#SBATCH --time=0-24:00
#SBATCH --ntasks-per-node=30
#SBATCH --exclusive
mpiexec -genv I_MPI_PIN_PROCESSOR_LIST=all:map=scatter -genv I_MPI_DEBUG=16 -genv I_MPI_PIN=1 ./executable file
result:
[root@head test_slurm]# cat slurm-108.out
Removing mpi version 2021.1.1
Loading mpi version 2021.1.1
The following have been reloaded with a version change:
1) mpi/2021.1.1 => mpi/latest
[0] MPI startup(): Intel(R) MPI Library, Version 2021.1 Build 20201112 (id: b9c9d2fc5)
[0] MPI startup(): Copyright (C) 2003-2020 Intel Corporation. All rights reserved.
[0] MPI startup(): library kind: release
Assertion failed in file ../../src/mpid/ch4/shm/posix/eager/include/intel_transport.c at line 389: llc_id >= 0
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(MPL_backtrace_show+0x1c) [0x7f412715259c]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(MPIR_Assert_fail+0x21) [0x7f4126a625f1]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x45531e) [0x7f41269dc31e]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x87b982) [0x7f4126e02982]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x6925ab) [0x7f4126c195ab]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x789186) [0x7f4126d10186]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x1a7432) [0x7f412672e432]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(+0x43e666) [0x7f41269c5666]
/opt/intel/oneapi/mpi/2021.1.1/lib/release/libmpi.so.12(MPI_Init+0xcb) [0x7f41269c4c7b]
/opt/intel/oneapi/mpi/2021.1.1/lib/libmpifort.so.12(MPI_INIT+0x1b) [0x7f41279f6d9b]
/home/hysintelmpi/NPB3.4-MZ/NPB3.4-MZ-MPI/bin/bt-mz.C.x() [0x42b4b1]
/home/hysintelmpi/NPB3.4-MZ/NPB3.4-MZ-MPI/bin/bt-mz.C.x() [0x404512]
/home/hysintelmpi/NPB3.4-MZ/NPB3.4-MZ-MPI/bin/bt-mz.C.x() [0x4044a2]
/lib64/libc.so.6(__libc_start_main+0xf3) [0x7f41254326a3]
/home/hysintelmpi/NPB3.4-MZ/NPB3.4-MZ-MPI/bin/bt-mz.C.x() [0x4043ae]
Abort(1) on node 16: Internal error
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= RANK 0 PID 207600 RUNNING AT c1
= KILLED BY SIGNAL: 9 (Killed)
= RANK 1 PID 207601 RUNNING AT c1
= RANK 2 PID 207602 RUNNING AT c1
= RANK 3 PID 207603 RUNNING AT c1
= RANK 4 PID 207604 RUNNING AT c1
= RANK 5 PID 207605 RUNNING AT c1
= RANK 6 PID 207606 RUNNING AT c1
= RANK 7 PID 207607 RUNNING AT c1
= RANK 8 PID 207608 RUNNING AT c1
= RANK 9 PID 207609 RUNNING AT c1
= RANK 10 PID 207610 RUNNING AT c1
PrasanthD_intel
Please tell us more about your environment details like the interconnect and provider you were using?
Let us know the value set for the I_MPI_PMI_LIBRARY environment variable? if it is empty try setting the I_MPI_PMI_LIBRARY environment variable to the Slurm Process Management Interface (PMI) library:
eg : export I_MPI_PMI_LIBRARY=/path/to/slurm/pmi/library/libpmi.so
Could you once try to check with srun instead of mpiexec?
Please check if you are facing the same error while submitting an interactive job?
Prasanth
PrasanthD_intel
Prasanth
PrasanthD_intel
We haven't heard back from you.
Have you tried the given alternatives?
If you are still facing the issue try using this command
mpirun -bootstrap slurm -n <num_procs> a.out
Let us know if it helps
Prasanth
PrasanthD_intel
We are closing this thread assuming your issue has been resolved.
We will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only
Prasanth
侯玉山
Hello! Thank you for your help. The problem has been resolved.
PrasanthD_intel
Thanks for the confirmation.
As your issue has been resolved, we are closing this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Prasanth
