hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® MPI Library
IMB_EXT no work
Blanco__Fernando
Dear experts,
I compiled the IMB benchmark with intel19 and openmpi-4.0.3. All test run ok except IMB_EXT.
If I run IMB_EXT in one node, all is ok, but if I run it in 2 nodes, when it runs de benchmark Accumulate, several are ok but for example,
accumulate process = 64 mode Aggregate only execute this
 #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]      defects
            0         1000         0.00         0.01         0.01         0.00
            4         1000         1.60         1.60         1.60         0.00
            8         1000         1.40         1.41         1.41         0.00
           16         1000         1.42         1.44         1.44         0.00
           32         1000         1.45         1.46         1.46         0.00
           64         1000         1.53         1.54         1.53         0.00
          128         1000         1.52         1.52         1.52         0.00
          256         1000         1.55         1.56         1.56         0.00
          512         1000         1.51         1.52         1.52         0.00
         1024         1000         1.66         1.68         1.68         0.00
         2048         1000         1.59         1.59         1.59         0.00
         4096         1000         2.48         2.49         2.49         0.00
         8192         1000         2.50         2.51         2.50         0.00
        16384         1000         3.68         3.69         3.69         0.00
The program doesn't finish, but it doesn't make anything
If I compile the test with CPPFLAGS=-DCHECK, I get errors in other accumulate test
# Benchmarking Accumulate
# #processes = 32
# ( 32 additional processes waiting in MPI_Barrier)
#    MODE: NON-AGGREGATE
            0          100         7.66         7.69         7.68         0.00
0: Error Accumulate,size = 4,sample #0
Process 0: Got invalid buffer:
Buffer entry: 105.599998
pos: 0
Process 0: Expected    buffer:
Buffer entry: 52.799999
            4          100       117.85       117.95       117.90         1.00
0: Error Accumulate,size = 8,sample #0
pos: 0
0: Error Accumulate,size = 4194304,sample #0
Buffer entry: 105.499992
pos: 0
      4194304           10    156021.70    194528.12    193324.60         0.00
# #processes = 64
#    MODE: AGGREGATE
And in this test not errors but it stop.
Any idea about this problem???
PrasanthD_intel
Hi Fernando,
We have tried to replicate the scenario using Intel MPI at our end but haven't faced any errors.
Could you tell us whether you are using the benchmarks that came with IMPI or are you cloning them from GitHub?
If possible could you update to the latest version of MPI and see if the error persists?
Prasanth
Blanco__Fernando
Hi Prasanth
I download the benchmarks from GitHub and I use openmpi-4.0.3. All test works fine, only the EXT was wrong.
PrasanthD_intel
Hi Fernando,
From the logs, it can be observed that the run stalled for 32 KB messages. This seems to me due to a large number of iterations (currently 1000).
1000 iterations might be too many for the some interconnect's.
Could you provide which interconnect you are using?
Can you check by reducing the number of iterations using the following flags,
-iter 20 -iter_policy off
The above flags will enforce 20 iterations for all message sizes and should let IMB complete significantly quicker.
Prasanth
Blanco__Fernando
With -iter 20 -iter_policy off it works!!!
Thank you very much!
PrasanthD_intel
Hi Fernando,
Good to know that the benchmark is running successfully.
Can we close this thread now?
You can always raise a new thread if you have any queries.
regards,
--Prasanth
PrasanthD_intel
Hi Fernando,
We are closing this thread considering your issue has been completely resolved.
Please raise a new thread for further queries.
Prasanth
