Intel® MPI Library
2275 Discussions
INTERNAL ERROR with SLURM and PMI2
John_D_6
I was pleasantly surprised to read that PMI2 & SLURM is supported by Intel MPI in the 2017 release. I tested it, but it fails immediately on my setup.  I'm using intel parallel studio 2017 update 4 & SLURM 15.08.13. A simple MPI-program doesn't work:
[donners@int1 pmi2]$ cat mpi.f90
program test
  use mpi
  implicit none
  integer ierr,nprocs,rank
  call mpi_init(ierr)
  call mpi_comm_size(MPI_COMM_WORLD,nprocs,ierr)
  call mpi_comm_rank(mpi_comm_world,rank,ierr)
  if (rank .eq. 0) then
    print *,'Number of processes: ',nprocs
  endif
  print*,'I am rank ',rank
  call mpi_finalize(ierr)
end
[donners@int1 pmi2]$ mpiifort mpi.f90
[donners@int1 pmi2]$ ldd ./a.out
    linux-vdso.so.1 =>  (0x00007ffcc0364000)
    libmpifort.so.12 => /opt/intel/parallel_studio_xe_2017_update4/compilers_and_libraries/linux/mpi/intel64/lib/libmpifort.so.12 (0x00002ad7432a9000)
    libmpi.so.12 => /opt/intel/parallel_studio_xe_2017_update4/compilers_and_libraries/linux/mpi/intel64/lib/release_mt/libmpi.so.12 (0x00002ad743652000)
    libdl.so.2 => /lib64/libdl.so.2 (0x00002ad744397000)
    librt.so.1 => /lib64/librt.so.1 (0x00002ad74459c000)
    libpthread.so.0 => /lib64/libpthread.so.0 (0x00002ad7447a4000)
    libm.so.6 => /lib64/libm.so.6 (0x00002ad7449c1000)
    libc.so.6 => /lib64/libc.so.6 (0x00002ad744c46000)
    libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002ad744fda000)
    /lib64/ld-linux-x86-64.so.2 (0x00002ad743086000)
[donners@int1 pmi2]$ I_MPI_PMI2=yes srun -n 1 --mpi=pmi2 ./a.out
INTERNAL ERROR: invalid error code ffffffff (Ring Index out of range) in MPID_Init:2104
Fatal error in MPI_Init: Other MPI error, error stack:
MPIR_Init_thread(805): fail failed
MPID_Init(1716)......: channel initialization failed
MPID_Init(2104)......: fail failed
srun: error: tcn1467: task 0: Exited with exit code 15
srun: Terminating job step 3270641.0
[donners@int1 pmi2]$ srun --version
slurm 15.08.13-Bull.1.0
The same problem occurs on a system with SLURM 17.02.3 (at TACC). What might be the problem here?
With regards,
John
James_S
Hi John, could you please try to export I_MPI_PMI_LIBRARY=/usr/lib64/libpmi.so to specify the full path to the libpmi.so library and then run it again? Thanks.
James_S
Hi John, Intel MPI has the binary incompatibility with libpmi2.so in some supports when in PMI2 mode and further binary compatibility is needed. Sorry for the inconvenience. Thanks.
John_D_6
thank you for the tip. I ran the test again with I_MPI_PMI_LIBRARY set to the locations of libpmi.so and libpmi2.so:
$ I_MPI_PMI_LIBRARY=/usr/lib64/libpmi.so I_MPI_PMI2=yes srun -n 1 --mpi=pmi2 ./a.out
srun: job 3324955 queued and waiting for resources
srun: job 3324955 has been allocated resources
srun: error: tcn866: task 0: Exited with exit code 15
srun: Terminating job step 3324955.0
$ I_MPI_PMI_LIBRARY=/usr/lib64/libpmi2.so I_MPI_PMI2=yes srun -n 1 --mpi=pmi2 ./a.out
srun: job 3324966 queued and waiting for resources
srun: job 3324966 has been allocated resources
 Number of processes:            1
 I am rank            0
so it works fine when I point to libpmi2.so (which seems pretty logical now).
The reason that I wanted to use PMI2 was its support for dynamically spawning MPI processes in a SLURM job. I used the following example to test dynamic spawning:
program mpispawn
  use mpi
  implicit none
  integer ierr,errcodes(1),intercomm,pcomm,mpisize,dumm,rank
  character(1000) cmd
  logical master
  call MPI_Init(ierr)
  call get_command_argument(0,cmd)
  print*,'cmd=',trim(cmd)
  call MPI_Comm_get_parent(pcomm,ierr)
  if (pcomm.eq.MPI_COMM_NULL) then
    print*,'I am the master. Clone myself!'
    master=.true.
    call MPI_Comm_spawn(cmd,MPI_ARGV_NULL,4,MPI_INFO_NULL,0,MPI_COMM_WORLD,pcomm,errcodes,ierr)
    call MPI_Comm_size(pcomm,mpisize,ierr)
    print*,'Processes in intercommunicator:',mpisize
    dumm=88
    call MPI_Bcast(dumm,1,MPI_INTEGER,MPI_ROOT,pcomm,ierr)
  else
    print*,'I am a clone. Use me'
    master=.false.
    call MPI_Bcast(dumm,1,MPI_INTEGER,0,pcomm,ierr)
  endif
  call MPI_Comm_rank(pcomm,rank,ierr)
  print*,'rank,master,dumm=',rank,master,dumm
  call sleep(10)
  call MPI_Barrier(pcomm,ierr)
  call MPI_Finalize(ierr)
end
I submitted this test program to SLURM with the following job script:
#!/bin/bash
#SBATCH -n 24
#SBATCH -p short
#SBATCH -c 1
#SBATCH --mem-per-cpu=1000
#SBATCH -t 5:00
# use PMI2
export I_MPI_PMI_LIBRARY=/usr/lib64/libpmi2.so
export PMI_DEBUG=1
export I_MPI_PMI2=yes
ldd  ./mpi.impi2017
srun -v --mpi=pmi2 -l -n 1 ./mpi.impi2017
The job output is:
        linux-vdso.so.1 =>  (0x00007ffeff7b9000)
        libmpifort.so.12 => /opt/intel/parallel_studio_xe_2017_update4/compilers_and_libraries/linux/mpi/intel64/lib/libmpifort.so.12 (0x00002ac75efff000)
        libmpi.so.12 => /opt/intel/parallel_studio_xe_2017_update4/compilers_and_libraries/linux/mpi/intel64/lib/debug_mt/libmpi.so.12 (0x00002ac75f3a8000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00000034bec00000)
        librt.so.1 => /lib64/librt.so.1 (0x00000034c0000000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00000034bf400000)
        libm.so.6 => /lib64/libm.so.6 (0x00000034bf800000)
        libc.so.6 => /lib64/libc.so.6 (0x00000034bf000000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00000034c0400000)
        /lib64/ld-linux-x86-64.so.2 (0x00000034be800000)
srun: defined options for program `srun'
srun: --------------- ---------------------
srun: user           : `donners'
srun: uid            : 31046
srun: gid            : 31060
srun: cwd            : /nfs/home1/donners/Tests/mpispawn
srun: ntasks         : 1 (set)
srun: cpus_per_task  : 1
srun: nodes          : 1 (set)
srun: jobid          : 3325083 (default)
srun: partition      : default
srun: profile        : `NotSet'
srun: job name       : `job.intel'
srun: reservation    : `(null)'
srun: burst_buffer   : `(null)'
srun: wckey          : `(null)'
srun: cpu_freq_min   : 4294967294
srun: cpu_freq_max   : 4294967294
srun: cpu_freq_gov   : 4294967294
srun: switches       : -1
srun: wait-for-switches : -1
srun: distribution   : unknown
srun: cpu_bind       : default
srun: mem_bind       : default
srun: verbose        : 1
srun: slurmd_debug   : 0
srun: immediate      : false
srun: label output   : true
srun: unbuffered IO  : false
srun: overcommit     : false
srun: threads        : 60
srun: checkpoint_dir : /var/slurm/checkpoint
srun: wait           : 60
srun: nice           : -2
srun: account        : (null)
srun: comment        : (null)
srun: dependency     : (null)
srun: exclusive      : false
srun: bcast          : false
srun: qos            : (null)
srun: constraints    : mincpus-per-node=1 mem-per-cpu=1000M
srun: geometry       : (null)
srun: reboot         : yes
srun: rotate         : no
srun: preserve_env   : false
srun: network        : (null)
srun: propagate      : NONE
srun: prolog         : /nfs/admin/scripts/admin/slurm_srunprolog
srun: epilog         : /nfs/admin/scripts/admin/slurm_srunepilog
srun: mail_type      : NONE
srun: mail_user      : (null)
srun: task_prolog    : (null)
srun: task_epilog    : (null)
srun: multi_prog     : no
srun: sockets-per-node  : -2
srun: cores-per-socket  : -2
srun: threads-per-core  : -2
srun: ntasks-per-node   : -2
srun: ntasks-per-socket : -2
srun: ntasks-per-core   : -2
srun: plane_size        : 4294967294
srun: core-spec         : NA
srun: power             :
srun: sicp              : 0
srun: remote command    : `./mpi.impi2017'
srun: launching 3325083.0 on host tcn1514, 1 tasks: 0
srun: route default plugin loaded
srun: Node tcn1514, 1 tasks started
0:  cmd=/nfs/home1/donners/Tests/mpispawn/./mpi.impi2017
0:  I am the master. Clone myself!
0: Fatal error in MPI_Init: Other MPI error, error stack:
0: MPIR_Init_thread(805).......: fail failed
0: MPID_Init(1949).............: spawn process group was unable to obtain parent port name from the channel
0: MPIDI_CH3_GetParentPort(465):  PMI2 KVS_Get failed: PARENT_ROOT_PORT_NAME
1: Fatal error in MPI_Init: Other MPI error, error stack:
1: MPIR_Init_thread(805).......: fail failed
1: MPID_Init(1949).............: spawn process group was unable to obtain parent port name from the channel
1: MPIDI_CH3_GetParentPort(465):  PMI2 KVS_Get failed: PARENT_ROOT_PORT_NAME
2: Fatal error in MPI_Init: Other MPI error, error stack:
2: MPIR_Init_thread(805).......: fail failed
2: MPID_Init(1949).............: spawn process group was unable to obtain parent port name from the channel
2: MPIDI_CH3_GetParentPort(465):  PMI2 KVS_Get failed: PARENT_ROOT_PORT_NAME
3: Fatal error in MPI_Init: Other MPI error, error stack:
3: MPIR_Init_thread(805).......: fail failed
3: MPID_Init(1949).............: spawn process group was unable to obtain parent port name from the channel
3: MPIDI_CH3_GetParentPort(465):  PMI2 KVS_Get failed: PARENT_ROOT_PORT_NAME
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
0: slurmstepd: *** STEP 3325083.1 ON tcn1514 CANCELLED AT 2017-07-14T10:39:01 ***
srun: error: tcn1514: tasks 0-3: Exited with exit code 1
srun: Terminating job step 3325083.1
This error message looks similar to a bug report for MPICH: https://github.com/pmodels/mpich/issues/1814
Maybe the bug fix mentioned at the end of that report is also applicable to Intel MPI. I get the same error message with the latest Intel MPI 2018b1.
Cheers,
John
