Intel® MPI Library
ITAC -- Naming generated .stf file to differentiate runs
drMikeT
I am using ITAC from the 2017.05 Intel Parallel Cluster Studio. I issue a number of mpirun command lines with ITAC tracing enabled. I am trying though to assign specific names to the generated .stf files so that I can associate the .stf files of a particular run with the corresponding mpirun command.
How can I do this?
Is there any option as we have for the statistics with the I_MPI_STATS_FILE?
Can I do something like
mpiexec.hydra ... -stf-file-name MPIapp_$(date +%F_%T) ... ./MPIapp
Thank you!
Michael
jimdempseyatthecove
# use 0 padding on left iterate 100 times (00:99)
for SequenceNumber in {00:99}
  do
    mpiexec.hydra ... -stf-file-name MPIapp_$SequenceNumber.sdf ... ./MPIapp
  done
Jim Dempsey
