Intel® MPI Library
2279 Discussions
Intel Cluster Studio: How many people can run MPI jobs simultaneously on a cluster with 2 sts floating licence
fr33guy
I know that if i buy a Intel Cluster Studio with a two user floating licence,
only two people would be able to compile their MPI codes simultaneously.
What i want to know is,
1) How many users can execute their MPI jobs simultaneously?
2) If i have codes compiled with Intel C compiler from the same cluster studio, how many people can execute their simultaneously?
Thanks in advance.
TimP
There's no application run-time checking against floating license limit, if the applications were previously linked under the limitations set by the license.
fr33guy
Sorry, but I didn't quite understand what you said.
Would any number of users be able to run their MPI binaries simultaneously?
Thanks and Regards
James_T_Intel
Yes, any number of users (as long as your system has sufficient resources) can run the binaries simultaneously.  The licensing restrictions are on the development end, not the runtime end.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
fr33guy
Thank you very much
