Intel® MPI Library
2300 Discussions
Intel Fortran Compiler 11.1 and OpenMPI 1.4 bug - Inconsistent Output
oacikgoz
Hi everyone,
I'm going nuts with my code, because what is happening is beyond my comprehension. When I compile my code with -g option, or -check all, or -check bounds flag, the code runs perfectly fine, though, as you can guess, very slow.
Whenever I use any optimization flag, the code fails to run, gives random segmentation faults. More importantly, the code has something of this sort:
x(1)=...
x(2)=...
x(64)=...
When I add WRITE(6,*) x(1) at the end, it gives me a number totally different from what I set it to. (gives me zero) x is an allocatable array which is properly allocated to be of size 64.
Here are some technical details:
I do not have Intel C/C++ compiler and therefore OpenMPI was compiled with gcc, g++ and ifort combined, with no special flags. If I use gfortran, the code runs with no problems, regardless of the optimization level.
I also tried to use MPICH2 and still the problem persists. It's not specific to OpenMPI. There is a compiler bug in Intel Compiler, or, there is an incompatibility between GCC 4.2 and ifort.
What do you think is the root of the problem?
Dmitry_K_Intel2
Hi oacikgoz,
I would not blame Intel compiler in this problem. Could you please download an evaluation copy of the Intel MPI library and give it a try. Download it from www.intel.com/go/mpi.
Pay attention that you need to use mpiifort for Intel Fortran Compiler.
Best wishes,
Dmitry
oacikgoz
Thanks for your reply. I cannot install MPI Intel because it's not available on Mac's. I'm using a 12-core Mac Pro with Mac OS X Installed.
Any other suggestions?
Dmitry_K_Intel2
oacikgoz,
If you are sure that the issue is related to Intel Fortran compiler you can submit a request via Premier porviding a reproducer.
Unfortunately we cannot help you with Mac OS because we don't even have this OS on our servers.
Best wishes,
Dmitry
oacikgoz
I just can't believe what I see. The compiler screws up for some reason for the following code whenever I use default optimization. When I turn off optimization it works just fine... Very odd. The screen output, when I run it on 4 nodes is,
-0.999305041735772 -0.999305041735772
-1.770442141520288E-003 -0.999305041735772
The correct output should have been
-0.999305041735772 1.783280721696433E-003
3.474791321139148E-004 1.783280721696433E-003
PROGRAM main
IMPLICIT NONE
INCLUDE 'mpif.h'
INTEGER :: rank
INTEGER :: nproc
INTEGER :: ierror
INTEGER :: i
INTEGER :: status(MPI_STATUS_SIZE)
REAL(8), DIMENSION(:), ALLOCATABLE :: xt
REAL(8), DIMENSION(:), ALLOCATABLE :: wt
REAL(8), DIMENSION(:), ALLOCATABLE :: outp
CALL MPI_INIT(ierror)
CALL MPI_COMM_RANK(MPI_COMM_WORLD,rank,ierror)
CALL MPI_COMM_SIZE(MPI_COMM_WORLD,nproc,ierror)
DO i=1,nproc
IF(rank==i-1) CALL preparevariables()
END DO
CALL MPI_FINALIZE(ierror)
CONTAINS
SUBROUTINE preparevariables()
IMPLICIT NONE
ALLOCATE(xt(64))
ALLOCATE(wt(64))
ALLOCATE(outp(64))
xt(1) = - 0.999305041735772139456905624346D+00
xt(2) = - 0.996340116771955279346924500676D+00
xt(3) = - 0.991013371476744320739382383443D+00
xt(4) = - 0.983336253884625956931299302157D+00
xt(5) = - 0.973326827789910963741853507352D+00
xt(6) = - 0.961008799652053718918614121897D+00
xt(7) = - 0.946411374858402816062481491347D+00
xt(8) = - 0.929569172131939575821490154559D+00
xt(9) = - 0.910522137078502805756380668008D+00
xt(10) = - 0.889315445995114105853404038273D+00
xt(11) = - 0.865999398154092819760783385070D+00
xt(12) = - 0.840629296252580362751691544696D+00
xt(13) = - 0.813265315122797559741923338086D+00
xt(14) = - 0.783972358943341407610220525214D+00
xt(15) = - 0.752819907260531896611863774886D+00
xt(16) = - 0.719881850171610826848940217832D+00
xt(17) = - 0.685236313054233242563558371031D+00
xt(18) = - 0.648965471254657339857761231993D+00
xt(19) = - 0.611155355172393250248852971019D+00
xt(20) = - 0.571895646202634034283878116659D+00
xt(21) = - 0.531279464019894545658013903544D+00
xt(22) = - 0.489403145707052957478526307022D+00
xt(23) = - 0.446366017253464087984947714759D+00
xt(24) = - 0.402270157963991603695766771260D+00
xt(25) = - 0.357220158337668115950442615046D+00
xt(26) = - 0.311322871990210956157512698560D+00
xt(27) = - 0.264687162208767416373964172510D+00
xt(28) = - 0.217423643740007084149648748989D+00
xt(29) = - 0.169644420423992818037313629748D+00
xt(30) = - 0.121462819296120554470376463492D+00
xt(31) = - 0.729931217877990394495429419403D-01
xt(32) = - 0.243502926634244325089558428537D-01
xt(33) = 0.243502926634244325089558428537D-01
xt(34) = 0.729931217877990394495429419403D-01
xt(35) = 0.121462819296120554470376463492D+00
xt(36) = 0.169644420423992818037313629748D+00
xt(37) = 0.217423643740007084149648748989D+00
xt(38) = 0.264687162208767416373964172510D+00
xt(39) = 0.311322871990210956157512698560D+00
xt(40) = 0.357220158337668115950442615046D+00
xt(41) = 0.402270157963991603695766771260D+00
xt(42) = 0.446366017253464087984947714759D+00
xt(43) = 0.489403145707052957478526307022D+00
xt(44) = 0.531279464019894545658013903544D+00
xt(45) = 0.571895646202634034283878116659D+00
xt(46) = 0.611155355172393250248852971019D+00
xt(47) = 0.648965471254657339857761231993D+00
xt(48) = 0.685236313054233242563558371031D+00
xt(49) = 0.719881850171610826848940217832D+00
xt(50) = 0.752819907260531896611863774886D+00
xt(51) = 0.783972358943341407610220525214D+00
xt(52) = 0.813265315122797559741923338086D+00
xt(53) = 0.840629296252580362751691544696D+00
xt(54) = 0.865999398154092819760783385070D+00
xt(55) = 0.889315445995114105853404038273D+00
xt(56) = 0.910522137078502805756380668008D+00
xt(57) = 0.929569172131939575821490154559D+00
xt(58) = 0.946411374858402816062481491347D+00
xt(59) = 0.961008799652053718918614121897D+00
xt(60) = 0.973326827789910963741853507352D+00
xt(61) = 0.983336253884625956931299302157D+00
xt(62) = 0.991013371476744320739382383443D+00
xt(63) = 0.996340116771955279346924500676D+00
xt(64) = 0.999305041735772139456905624346D+00
wt(1) = 0.178328072169643294729607914497D-02
wt(2) = 0.414703326056246763528753572855D-02
wt(3) = 0.650445796897836285611736039998D-02
wt(4) = 0.884675982636394772303091465973D-02
wt(5) = 0.111681394601311288185904930192D-01
wt(6) = 0.134630478967186425980607666860D-01
wt(7) = 0.157260304760247193219659952975D-01
wt(8) = 0.179517157756973430850453020011D-01
wt(9) = 0.201348231535302093723403167285D-01
wt(10) = 0.222701738083832541592983303842D-01
wt(11) = 0.243527025687108733381775504091D-01
wt(12) = 0.263774697150546586716917926252D-01
wt(13) = 0.283396726142594832275113052002D-01
wt(14) = 0.302346570724024788679740598195D-01
wt(15) = 0.320579283548515535854675043479D-01
wt(16) = 0.338051618371416093915654821107D-01
wt(17) = 0.354722132568823838106931467152D-01
wt(18) = 0.370551285402400460404151018096D-01
wt(19) = 0.385501531786156291289624969468D-01
wt(20) = 0.399537411327203413866569261283D-01
wt(21) = 0.412625632426235286101562974736D-01
wt(22) = 0.424735151236535890073397679088D-01
wt(23) = 0.435837245293234533768278609737D-01
wt(24) = 0.445905581637565630601347100309D-01
wt(25) = 0.454916279274181444797709969713D-01
wt(26) = 0.462847965813144172959532492323D-01
wt(27) = 0.469681828162100173253262857546D-01
wt(28) = 0.475401657148303086622822069442D-01
wt(29) = 0.479993885964583077281261798713D-01
wt(30) = 0.483447622348029571697695271580D-01
wt(31) = 0.485754674415034269347990667840D-01
wt(32) = 0.486909570091397203833653907347D-01
wt(33) = 0.486909570091397203833653907347D-01
wt(34) = 0.485754674415034269347990667840D-01
wt(35) = 0.483447622348029571697695271580D-01
wt(36) = 0.479993885964583077281261798713D-01
wt(37) = 0.475401657148303086622822069442D-01
wt(38) = 0.469681828162100173253262857546D-01
wt(39) = 0.462847965813144172959532492323D-01
wt(40) = 0.454916279274181444797709969713D-01
wt(41) = 0.445905581637565630601347100309D-01
wt(42) = 0.435837245293234533768278609737D-01
wt(43) = 0.424735151236535890073397679088D-01
wt(44) = 0.412625632426235286101562974736D-01
wt(45) = 0.399537411327203413866569261283D-01
wt(46) = 0.385501531786156291289624969468D-01
wt(47) = 0.370551285402400460404151018096D-01
wt(48) = 0.354722132568823838106931467152D-01
wt(49) = 0.338051618371416093915654821107D-01
wt(50) = 0.320579283548515535854675043479D-01
wt(51) = 0.302346570724024788679740598195D-01
wt(52) = 0.283396726142594832275113052002D-01
wt(53) = 0.263774697150546586716917926252D-01
wt(54) = 0.243527025687108733381775504091D-01
wt(55) = 0.222701738083832541592983303842D-01
wt(56) = 0.201348231535302093723403167285D-01
wt(57) = 0.179517157756973430850453020011D-01
wt(58) = 0.157260304760247193219659952975D-01
wt(59) = 0.134630478967186425980607666860D-01
wt(60) = 0.111681394601311288185904930192D-01
wt(61) = 0.884675982636394772303091465973D-02
wt(62) = 0.650445796897836285611736039998D-02
wt(63) = 0.414703326056246763528753572855D-02
wt(64) = 0.178328072169643294729607914497D-02
WRITE(*,*) xt(1),wt(1)
xt=(xt+1.0D0)*0.5D0
END SUBROUTINE preparevariables
END PROGRAM main
oacikgoz
One more thing, I just realized that this has nothing to do with MPI. Commenting out MPI related lines also reproduces the same error...
Dmitry_K_Intel2
