Intel® MPI Library
2285 Discussions
Intel MPI 4.0.1 with OSC mpiexec unable to launch properly
slyleo
Hi All,
I am willing to use OSC mpiexec on our cluster, as we had success with it with MVAPICH2, and Intel MPI's PMs don't work well enough in our PBS/Torque based environment.There is this relevant thread.
However, I wasn't able to run it successfully. The MPI process is launched with correct number of processes, on correct hosts, but the MPI processes don't see each other, run independently as if comm size is 1.
I am using Intel MPI 4.0.1.007 and OSC mpiexec 0.84. Tried with -comm pmi and -comm mpich2-pmi, same issue.
Thanks ahead for any pointers/help!
Dmitry_K_Intel2
Hi Slyleo,
Unfortunately we don't officially support OSC's mpiexec. But you can try the following: set I_MPI_PMI_EXTENSIONS=on on your system. It should help you.
Regards!
Dmitry
slyleo
I just tested with earlier version, Intel MPI 4.0.0. To my (great!) surprise it works just fine.
Dmitry_K_Intel2
Hi Slyleo,
Regards!
Dmitry
slyleo
That works! Thank you.
