Intel® MPI Library
2301 Discussions
Intel MPI : Fortran 2008 Error
aruhela
Hi Intel Support Team,
One of our staff is trying to compile a Fortran 2008 program with GNU Fortran compilers.  He has observed, "f951: Fatal Error: Reading module 'mpi_f08' at line 1 column 2: Unexpected EOF" for the line "use mpi_f08" in his program.
Program count.F90
  use mpi_f08
end Program GetCount
[staff f08:467] module load intel Lmod is automatically replacing "gcc/9.1.0" with "intel/19.1.1". Due to MODULEPATH changes, the following have been reloaded: 1) impi/19.0.9 2) petsc/3.16 3) python3/3.9.2
[staff f08:468] mpif90 -c count.F90 [staff f08:469] module load gcc Lmod is automatically replacing "intel/19.1.1" with "gcc/9.1.0". Due to MODULEPATH changes, the following have been reloaded: 1) impi/19.0.9 2) petsc/3.16 3) python3/3.9.2
[staff f08:470] mpif90 -c count.F90 f951: Fatal Error: Reading module 'mpi_f08' at line 1 column 2: Unexpected EOF compilation terminated.
As the documentation on the Intel webpage https://www.intel.com/content/www/us/en/developer/articles/release-notes/mpi-library-release-notes-linux.html show Fortran 2008 bindings are supported in intel MPI,  could you please suggest us a solution to the issue?
Amit Ruhela
HemanthCH_Intel
We are able to reproduce your issue on Ubuntu 18.04. we will get back to you soon regarding this issue.
However, we tried compiling the below-attached sample code(hello.f90) using mpiifort which worked fine.
Thanks & Regards,
Hemanth
HemanthCH_Intel
>>"We are able to reproduce your issue on Ubuntu 18.04. we will get back to you soon regarding this issue."
Intel MPI doesn't support f08 bindings with gfortran (mpif90 wrapper)in Linux. You can only build it with ifort (mpiifort).
Thanks & Regards,
Hemanth
aruhela
Thanks Hemanth,
Do you plan to add support in further releases?
Amit
HemanthCH_Intel
>>"Do you plan to add support in further releases?"
Could you please refer to the release notes for the latest information, known issues, and limitations of Intel MPI in future releases?
Thanks & regards,
Hemanth,
aruhela
Thanks Hemanth,
We wish to see the f08 binding in the next software release. You may close the ticket.
HemanthCH_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks & Regards,
Hemanth.
