Intel® MPI Library
2298 Discussions
Intel MPI Internal Crash on Local Multi-Rank Execution
fairussiam55
Issue:
Intel MPI 2021.15 (Build 20250213) crashes with SIGFPE when running any MPI program with more than 1 process locally.
System:
  • Single-node setup (node1-X99)
  • OS: Ubuntu-based
  • MPI initialized via source /opt/intel/oneapi/setvars.sh
Command:
mpiexec -n 4 ./hello_mpi
Minimal code (hello_mpi.c):
#include <mpi.h>
#include <stdio.h>
int main(int argc, char** argv) {
MPI_Init(&argc, &argv);
int rank, size;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm_size(MPI_COMM_WORLD, &size);
printf("Hello from rank %d of %d\n", rank, size);
MPI_Finalize();
return 0;
Error (strace output):
--- SIGFPE (Floating point exception) ---
+++ killed by SIGFPE (core dumped) +++
Notes:
Works with -n 1
Fails with fork, tcp, shm, and default launchers
/tmp permissions and environment are correct
Likely internal bug in the MPI runtime (e.g., division by zero)
Deeksha_S_Intel
Hi Mohd, we would like to inform you that we are routing your query to the engineering team for further assistance.
taehunkim
The code you shared works well without any error as below.
Would you like to re-install oneAPI?
