Intel® MPI Library
Intel MPI fatal error
atrash
We compiled a code which is able to performe atomistic simulations.
The code fail with the folowing error.
I'll be thankful ifyou can help me in fixing this prolem.
Thank you in advance,
Fouad
[0:node44][../../dapl_module_poll.c:3972] Intel MPI fatal error: OpenIB-cma DTO operation posted for [2:node58] completed with error. status=0x1. cookie=0x40002
Assertion failed in file ../../dapl_module_poll.c at line 3973: 0
internal ABORT - process 0
[2:node58][../../dapl_module_poll.c:3972] Intel MPI fatal error: OpenIB-cma DTO operation posted for [0:node44] completed with error. status=0x6. cookie=0x40000
internal ABORT - process 2
[1:node44] unexpected disconnect completion event from [2:node58]
Assertion failed in file ../../dapl_module_util.c at line 1593: 0
internal ABORT - process 1
[3:node58] unexpected disconnect completion event from [0:node44]
internal ABORT - process 3
[6:node28] unexpected disconnect completion event from [0:node44]
[7:node28] unexpected disconnect completion event from [0:node44]
internal ABORT - process 7
internal ABORT - process 6
[5:node59] unexpected disconnect completion event from [0:node44]
[4:node59] unexpected disconnect completion event from [0:node44]
internal ABORT - process 4
internal ABORT - process 5
rank 0 in job 1 node44_33470 caused collective abort of all ranks
exit status of rank 0: return code 1
[Ending Job 36715]
Dmitry_K_Intel2
Hi Fouad,
It can be useful to know Intel MPI version, DAPL version, Fabric (or Device) used in that run, the whole command line. What fast fabric do use (Infiniband)?
Regards!
Dmitry
