Intel® MPI Library
maximum size
Jose_Gordillo
I was wondering which is the maximum size of a data structure that can be send via MPI_Ssend or MPI_Broadcast. I suppose it's implementation dependent. If so, which factors determine it?
thanks in advance,
Dmitry_K_Intel2
Hi Joe,
It seems to me that internal implementation of MPI functions may limit the maximum size of a structure which can be transferred at once. But I think that it should not be less than 2GB. You can write a small test case and check this limitation.
Regards!
Dmitry
