Intel® MPI Library
Intel MPI gives wrong number of physical cores on core i7 Q820?
Anders_S_1
New Contributor III
I have begun learning MPI on my Dell 4500 with a Core i7 Q820 processor (4 physical and 8 logical cores).
When I run a simple program in Fortran to get the rank and size, i get 0 and 1 instead of 0 and 3 (see attached code).
What is wrong?
Best regards
Anders S
Artem_R_Intel1
Hi Anders,
As far as I understand you run the MPI program without MPI launcher (like mpirun), correct?
$ ./mpitest
rank,size=   0   1
It's similar to:
$ mpirun -n 1 ./mpitest
rank,size=   0   1
Why do you expect '0 and 3'?
You can try to vary the number of MPI processes with '-n <procs>' option:
$ mpirun -n 4 ./mpitest
rank,size=   1   4
rank,size=   2   4
rank,size=   3   4
rank,size=   0   4
I'd recommend to look at the Getting Started with Intel® MPI Library document.
Artem_R_Intel1
Hi Anders,
$ ./mpitest
rank,size=   0   1
It's similar to:
rank,size=   0   1
rank,size=   1   4
rank,size=   2   4
rank,size=   3   4
rank,size=   0   4
Anders_S_1
New Contributor III
Artem R. (Intel) wrote:
Hi Anders,
$ ./mpitest
rank,size=   0   1
It's similar to:
rank,size=   0   1
rank,size=   1   4
rank,size=   2   4
rank,size=   3   4
rank,size=   0   4
Hi Artem,
Thank you for your answer!
My Dell M4500 broke down and I have continued with a Dell M4800 with a Core i7 4910MQ processor.
Furthermore, I have installed the Parallell Studio Cluster software.
When I run the simple test code (attached) with no use of MPI compile, link and run was OK.
When I added just the line
INCLUDE 'mpif.h'
compile was OK but link gave a number of warnings and errors (attached link message printout)
What have I missed?
Best regards
Anders S
James_T_Intel
Did you add impi.lib to your library input?
Anders_S_1
New Contributor III
Hi James,
Thanks for your answers. As I just after your first reply installed the Cluster studio I found it better to start a new, hopefully better defined case called "Trying to make MPI work in a QuickWin application". I think your last comment may be relevant in the new case.
Best regards
Anders S
