Intel® MPI Library
2294 Discussions
Intel MPI multinode jobs running problems
Jenya
I have a four-node cluster connected by infiniband switch. I have a common NFS home directory for each node. The startup sequence for each node (bashrc, etc.) is thus identical. Let's call the nodes, node1, node2, and node3. I have disabled the firewalls on each server (which are running OS version of Rocky 8.7).
We have a PBS PRO (pbs_version = 2022.1.4.20231010124201
) queuing system and when we run jobs on a single node everything works fine, but when we try to run jobs in multinode mode we get the following errors:
check_exit_codes (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:117): unable to run bstrap_proxy on node1
poll_for_event (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:159): check exit codes error
HYD_dmx_poll_wait_for_proxy_event (../../../../../src/pm/i_hydra/libhydra/demux/hydra_demux_poll.c:212): poll for event error
HYD_bstrap_setup (../../../../../src/pm/i_hydra/libhydra/bstrap/src/intel/i_hydra_bstrap.c:1065): error waiting for event
HYD_print_bstrap_setup_error_message (../../../../../src/pm/i_hydra/mpiexec/intel/i_mpiexec.c:1026): error setting up the bootstrap proxies
Also in cluster Intel® oneAPI HPC Toolkit 2023 installed.
I would be happy to provide additional information if needed.
VeenaJ_Intel
Thanks for posting in Intel communities!
Can you please try setting up the following Environment variable:
export I_MPI_HYDRA_IFACE="ib0"
After implementing this change, kindly execute the process in a multinode environment and share the results with us.
Additionally, we kindly request the following details for further investigation:
  • Reproducer code.
  • Recreation steps.
  • Interconnect hardware details.
  • FI_PROVIDER information.
  • Logs generated after running the Intel® MPI Benchmark (IMB) with the same number of nodes as in the case where the issue occurred.
We thank you in advance for your cooperation.
Veena
Jenya
Hi Veena,
We are going to check what you wrote earlier and provide you with the results.
BR,
Jenya.
TobiasK
@Jenya
in case you still have problems, please open a new thread.
