Intel® MPI Library
2279 Discussions
Intel Trace Analyzer and Collector with MS-MPI
Hodara__Joachim1
I would like to analyze my MS-MPI application using ITAC. I created a simple sample main.cpp:
#include <iostream>
#include <mpi.h>
int main(int argc, char **argv)
  MPI_Init(&argc, &argv);
  int world_size;
  MPI_Comm_size(MPI_COMM_WORLD, &world_size);
  int my_rank;
  MPI_Comm_rank(MPI_COMM_WORLD, &my_rank);
  std::cout << "World Size: " << world_size << "   Rank: " << my_rank << std::endl;
  MPI_Finalize();
  return 0;
which I compile using MSVC/MS-MPI (16.9.2):
cl main.cpp /I"C:\Program Files (x86)\Microsoft SDKs\MPI\Include"  /c
link /machine:x64 "msmpi.lib" /libpath:"C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x64" main.obj
The application runs just fine:
>mpiexec -n 4 ./main.exe
World Size: 4   Rank: 3
World Size: 4   Rank: 2
World Size: 4   Rank: 1
World Size: 4   Rank: 0
I used the same procedure to compile and run the ITAC MPI compatibility checker, and it passed:
Intel(R) Trace Analyzer and Collector is compatible with your MPI version.
So far, so good. However, I don't understand how I can enable mpi-tracing with MS-MPI. The documentation says that I should recompile the code using the -trace option, but that option does not exist in MSVC. They seem to have something vaguely similar, but it generates .etl files rather than .stf files.
What should I do to generate a .stf file on Windows with MSVC/MS-MPI?
Thank you for your help,
Joachim
VarshaS_Intel
We are working on your issue. We will get back to you soon.
Thanks & Regards,
Varsha
VarshaS_Intel
Could you please try using the below commands in command prompt(after sourcing the Intel oneAPI environment) to generate the .stf file:
For Compiling the MPI code:
mpicc -trace <program_name>.cpp
For Running the MPI code:
mpiexec -n <number_of_processes> <program_name>.exe
To Trace the MPI code using the Intel Trace Analyzer and Collector:
traceanalyzer <program_name>.stf
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need additional information, please post a new question.
Thanks & Regards,
Varsha
