Intel® MPI Library
2284 Discussions
Intel mpi calling pbsdsh with incorrect options for PBSPro 2022
CharlesWright
It fails because Intel mpi is calling pbsdsh with -h and that is not a valid flag for pbsdsh.
There also should be a -- before calling hydra_bstrap_proxy.
Usage: /opt/pbs/bin/pbsdsh [-c copies][-s][-v][-o] -- program [args...]
       /opt/pbs/bin/pbsdsh [-n node_index][-s][-v][-o] -- program [args...]
       /opt/pbs/bin/pbsdsh --version
Where -c copies =  run a copy of "program" on the first "copies" nodes,
      -n node_index = run a copy of "program" on the "node_index"-th node,
      -s = forces synchronous execution,
      -v = forces verbose output.
      -o = no obits are waited for.
We are forced to do
export I_MPI_HYDRA_BOOTSTRAP=ssh
Wondering what version of pbsdsh Intel MPI is tested against and if it could be made to do the right thing for PBS Pro.
CharlesWright
We tested 2024.2 and issue appears to be fixed there.
CharlesWright
