Intel® MPI Library
Intel mpirun error - AI workload
Naveen_T_Intel
  I tried to run one of my workload model for training on a CentOs cluster for MPI analysis. Please find below the command used and the error is displayed below. Request your help in resolving the issue.
Commands used
mpiexec  –ppn 1 -- ./scripts/run_intelcaffe.sh --hostfile ~/mpd.hosts --solver models/intel_optimized_models/multinode/resnet50_8nodes_2s/solver.prototxt --network tcp --netmask enp175s0 --benchmark mpi
mpirun  –ppn 1 –l amplxe-cl -collect hotspots -k sampling-mode=hw -result-dir results -- ./scripts/run_intelcaffe.sh --hostfile ~/mpd.hosts --solver models/intel_optimized_models/multinode/resnet50_8nodes_2s/solver.prototxt --network tcp --netmask enp175s0 --benchmark mpi
I keep getting the following error.
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   RANK 26 PID 72362 RUNNING AT node001
=   EXIT STATUS: 255
=   RANK 27 PID 72363 RUNNING AT node001
=   KILLED BY SIGNAL: 9 (Killed)
Maksim_B_Intel
Hi, Thallam. Do I get it right you get a crash without ampxle too?
Let's check if issue is in environment/mpirun area, by running a simpler test, like:
mpiexec.hydra -n 2 IMB-MPI1 Barrier
Try supplying -n <process_count> argument, in case your scheduler provides node list to mpiexec too.
A run with -v option and I_MPI_DEBUG=10 will give you a longer log, which you can post here.
