Intel® MPI Library
IntelMPI Intel19 update 4 error
dona__lorenzo
Dear All Good afternoon I successfully installed intel parallel studio 19 update 4 on my cluster based on Ubuntu 18.04 LTS The cluster is composed by 4 nodes: a master and 3 other nodes where I run my calculations. I am able to run calculations on the master only or on the nodes only or togheter. But when I try to ask for master+ one of the nodes I receive this message error: Abort(543240207) on node 7 (rank 7 in comm 0): Fatal error in PMPI_Bcast: Other MPI error, error stack: PMPI_Bcast(452)...................: MPI_Bcast(buf=0x5b7cee0, count=10, MPI_INTEGER, root=7, comm=MPI_COMM_WORLD) failed PMPI_Bcast(438)...................: MPIDI_SHMGR_Gather_generic(391)...: MPIDI_NM_mpi_bcast(161)...........: MPIR_Bcast_intra_tree(227)........: Failure during collective MPIR_Bcast_intra_tree(219)........: MPIR_Bcast_intra_tree_generic(180): Failure during collective And also when I run the MPI-Benchmarks as : mpirun -hosts master,node1 -n 2 -ppn 1 /opt/intel/compilers_and_libraries_2019.4.243/linux/mpi/intel64/bin/IMB-MPI1 I receive this error message Abort(609312527) on node 1 (rank 1 in comm 0): Fatal error in PMPI_Comm_split: Other MPI error, error stack: PMPI_Comm_split(507)........................: MPI_Comm_split(MPI_COMM_WORLD, color=0, key=1, new_comm=0x6de6e4) failed PMPI_Comm_split(489)........................: MPIR_Comm_split_impl(167)...................: MPIR_Allgather_intra_auto(145)..............: Failure during collective MPIR_Allgather_intra_auto(141)..............: MPIR_Allgather_intra_recursive_doubling(126): MPIC_Sendrecv(344)..........................: MPID_Isend(662).............................: MPID_isend_unsafe(282)......................: MPIDI_OFI_send_lightweight_request(106).....: (unknown)(): Other MPI error I tried also to install parallel studio 19 update 5 but the problem is still the same All the best Lorenzo
PrasanthD_intel
We are working on this query and will get back to you.
Prasanth
dona__lorenzo
Thanks to help me and for your fast reply
I give you more details of my cluster.
The master node is also the login node and it has 2 IP address as reported below:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.101  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::ec4:7aff:fe78:73f4  prefixlen 64  scopeid 0x20<link>
        ether 0c:c4:7a:78:73:f4  txqueuelen 1000  (Ethernet)
        RX packets 102348  bytes 25759571 (25.7 MB)
        RX errors 0  dropped 35  overruns 0  frame 0
        TX packets 35752  bytes 5759844 (5.7 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device memory 0xc7d00000-c7d7ffff
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.0.0.1  netmask 255.255.255.0  broadcast 10.0.0.255
        inet6 fe80::ec4:7aff:fe78:73f5  prefixlen 64  scopeid 0x20<link>
        ether 0c:c4:7a:78:73:f5  txqueuelen 1000  (Ethernet)
        RX packets 95984811  bytes 103960161249 (103.9 GB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 98633593  bytes 109716265658 (109.7 GB)
        device memory 0xc7c00000-c7c7ffff
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Loopback locale)
        RX packets 176450  bytes 1091561329 (1.0 GB)
        TX packets 176450  bytes 1091561329 (1.0 GB)
while the noes have the follow ip configuration:
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 0c:c4:7a:76:17:1c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
        inet 10.0.0.2  netmask 255.255.255.0  broadcast 10.0.0.255
        inet6 fe80::8713:663e:8261:e7d4  prefixlen 64  scopeid 0x20<link>
        ether 0c:c4:7a:76:17:1d  txqueuelen 1000  (Ethernet)
        RX packets 213840131  bytes 232703810855 (232.7 GB)
        RX errors 49  dropped 0  overruns 0  frame 36
        TX packets 210730735  bytes 225976171140 (225.9 GB)
        RX packets 283037  bytes 1284137604 (1.2 GB)
        TX packets 283037  bytes 1284137604 (1.2 GB)
and here you can find the list of the hosts
127.0.0.1       localhost
10.0.0.1        master
10.0.0.2        node1
10.0.0.3        node2
10.0.0.4        node3
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
I also tested parallel_studio_2017_update_4 and everything works fine
All the best
lorenzo
Klaus-Dieter_O_Intel
