Intel® MPI Library
2302 Discussions
OpenMP offload hangs if omp_get_num_threads used inside parallel team?
CFR
New Contributor II
Lenovo T570, Ubuntu 18.04.4, icpc (ICC) 2021.1 Beta 20200602
Given the following example code:
#include <omp.h>
#include <cstdio>
int
main(int argc, char *argv[])
  printf("Devices= %d\n", omp_get_num_devices());
  printf("Initial device %d (is initial %c)\n", omp_get_initial_device(), omp_is_initial_device()?'Y':'N');
  printf("Default device %d\n", omp_get_default_device());
//#pragma omp target parallel
//#pragma omp target parallel for
//#pragma omp target teams
//#pragma omp target teams distribute
//#pragma omp target teams distribute parallel for
  for (int i=0; i<8; i++)
    printf( "%d Team %d of %d, Thread %d of %d\n", i,
        omp_get_team_num(), omp_get_num_teams(),
        omp_get_thread_num(), omp_get_num_threads());
Compiled as follows:
icpc -std=c++17 -O3 -o bug1 bug1.cpp -qnextgen -fiopenmp -fopenmp-targets=spir64
Commenting out any of the pragma lines containing "parallel" and the code will hang when executed.  The non-"parallel" pragmas work correctly.  The problem seems to be omp_get_num_threads().  If you remove that from the print statement then all the pragma lines result in execution that works.
I'm new to this offloading part of OpenMP but seems to me it should work properly?
PrasanthD_intel
Hi Craig,
This thread is a duplicate of https://community.intel.com/t5/Intel-oneAPI-HPC-Toolkit/OpenMP-offload-hangs-if-omp-get-num-threads-used-in-target-quot/m-p/1189420#M6891.
Since there is no problem with teams both the threads raised by you are dealing with the same issue.
We are closing this thread. Please follow the above thread for the solution.
Prasanth
PrasanthD_intel
Hi Craig,
Prasanth
CFR
New Contributor II
Sorry the duplicate happened when the new system was flagging everything as SPAM.  I was trying to get around the filter then someone "released" all the various attempts.
