Intel® MPI Library
Interrupted system call from gprof
Viet-Duc
When we compile with '-pg' option, the following message was received during execution.
hfi_userinit: assign_context command failed: Interrupted system call
hfp_gen1_context_open: hfi_userinit: failed, trying again (1/3)
 rank           0 : Hello, World!
 rank           1 : Hello, World!
This causes code performing heavy numerical computations to hang.
The only related information we can find on this issue is from Intel OPA repo: https://github.com/intel/opa-psm2/issues/28
Here are our system information:
- Linux 3.10.0-1062.el7.x86_64
- Intel 2019 Update 5
- hfi1-firmware-0.9-84
We appreciate your insight on how to minimize the interrupted system calls.
Regards.
PrasanthD_intel
Are you getting this message for every execution or is this a random thing?
Can you provide details like which compiler you are using and the version?
Please provide the compilation and execution commands you are using.
Prasanth
Viet-Duc
We've repeated the 'hello, world' test 10 times for each different numbers of MPI rank.
The compilation was done with Intel Fortran Compiler and Intel MPI library 2019 update 5, as mentioned in the first post.
mpiifort -pg hello.f90 -o hello.x
The execution was done as follow:
mpirun -np #nranks ./hello.x
(Where nranks = 1, 2, 4, 8, 16)
Even with just one sole MPI rank, the message appears randomly, and on an average of 4/10 times for small number of ranks.
When the number of ranks exceed 16, the message always appears at the beginning of execution
I hope it can help with the diagnosis.
PrasanthD_intel
Please provide us the log info with the following flags set.
export I_MPI_DEBUG=5
export FI_LOG_LEVEL=debug
Prasanth
Viet-Duc
A apologize for the wall of text. The following debug information was generated using 2 MPI ranks.
No 'Interrupted system call': https://justpaste.it/57lp1
With 'Interrupted system call': https://justpaste.it/3t6r2
The aforementioned message was occurred between calls to libfabric:psm2:core:psmx2_trx_ctxt_alloc()
libfabric:psm2:core:psmx2_trx_ctxt_alloc():282<info> uuid: 00FF00FF-0000-0000-0000-00FF00FF00FF
libfabric:psm2:core:psmx2_trx_ctxt_alloc():287<info> ep_open_opts: unit=-1 port=0
node8102.17670hfi_userinit: assign_context command failed: Interrupted system call
node8102.17670hfp_gen1_context_open: hfi_userinit: failed, trying again (1/3)
libfabric:psm2:core:psmx2_trx_ctxt_alloc():320<info> epid: 0000000003d30d02 (tx+rx)
libfabric:psm2:core:psmx2_am_init():116<info> epid 0000000003d30d02
PrasanthD_intel
We are escalating your issue to the respective team.
Prasanth
Viet-Duc
I included here more data in case it may help with diagnosis.
1. 'Hello, World!' random test:
    n = 1: 4/10 (i.e. 1 MPI rank, 4 of 10 times the "Interrupted system call" appears)
    n = 2: 2/10
    n = 4: 5/10
    n = 8: 10/10
    n = 16: 10/10
    With sufficiently large MPI ranks, the message always appears at beginning of the execution.
2. Single-node test: VASP (5.4.4), QE(6.5), LAMMPS(12Dec18), GROMACS(2019.6)
    Output from widely-used codes are attached in the zip file. Tests were conducted on KNL architecture using 64 MPI ranks.
3. Multi-node test:
    For more than 1024 MPI ranks, calculation may, but not always, crash with following error message:
node8054.60631PSM2 can't open hfi unit: -1 (err=23)
node8054.60632PSM2 can't open hfi unit: -1 (err=23)
Abort(1615759) on node 338 (rank 338 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
MPIR_Init_thread(703)........:
MPID_Init(923)...............:
MPIDI_OFI_mpi_init_hook(1211):
create_endpoint(1892)........: OFI endpoint open failed (ofi_init.c:1892:create_endpoint:Invalid argument)
Abort(1615759) on node 339 (rank 339 in comm 0): Fatal error in PMPI_Init: Other MPI error, error stack:
The testing environment is same as outlined in our first post. We are open to your suggestions for further tests.
Kevin_O_Intel1
Sorry for the delay. I wanted to let you know I filed a bug report. Will let you know the status of the issue.
Kevin_O_Intel1
Looking through some older threads... do you still need assistance here?
cisong1
I hope to know about this issue.  Could you let me know whether this issue was solve or not it?
Kevin_O_Intel1
Carlospdp
Pls can you provide and updated link or solution, thank you.
Carlospdp
The link no longer works, do you know if there is a way of fixing the error without removing the -pg flag.
