Intel® MPI Library
2275 Discussions
Is there any difference between I_MPI_HYDRA_ENV=all and mpirun -genvall?
JSCHO
Hi.
Perhaps this is a stupid beginner’s question, but anyway: I know that I_MPI_HYDRA_ENV=all is the default. Does this imply “mpirun -genvall”? Or is there any difference between these approaches of defining and passing configuration settings for the IMPI?
Or in other words: If I need to define settings like, e.g., I_MPI_HYDRA_BOOTSTRAP and I_MPI_CBWR, will it be sufficient to define these settings as environment variables, or will I also have to add arguments to the mpirun command like -genvall or -genv I_MPI_CBWR=x?
Thanks in advance for an explanation.
Jan
TobiasK
@JSCHO no you don't need to use -genv I_MPI_CBWR or -genvall
TobiasK
JSCHO
Thanks for your reply. That's what I suspected.
Just out of curiosity: Since defining I_MPI_* environment variables is sufficient, what is the purpose of the mpirun option "-genv*"?
JSCHO
Thank you for the explanation.
