Intel® MPI Library
2288 Discussions
Is there any performance or space overheads for using 'tag' in MPI?
seongyun_k_
I wonder if  there can be any performance or space overheads for using 'tag' in MPI.
It would depend on how it is implemented, but I guess if it used a sort of hash map and keep (possible) multiple buffers for the buckets. The process memory size can blow up.
Can this happen?
Judith_W_Intel
James_T_Intel
What tag are you talking about?  Is this related to the MPI tag used in point-to-point communications?  This is part of the standard and is required.
