Intel® MPI Library
2287 Discussions
MKL ScaLAPACK + MVAPICH + 100 lines of code = CRASH
amolins
The following code has proved good to generate a crash using MKL 10.2 update 2 (sequential version and threaded), last revision of MVAPICH, in two different clusters. Can anybody tell me what the problem is here? It does not crash always, but it does crash when the right number of MPI processes and matrix sizes are selected.
A
* crash.cpp - crashes with ICC 11.1, MKL 10.2, MVAPICH 1.0 on linux 64-bit
* both linked with the serial or threaded libraries
* doing mpirun -np 36 crash 5000 10
#include
#include
#include
#include
#include"mpi.h"
#include "mkl_scalapack.h"
extern "C" {
/* BLACS C interface */
void Cblacs_get(int context,int request,int* value);
int Cblacs_gridinit(int* context,char * order,int np_row,int np_col);
void Cblacs_gridinfo(int context,int* np_row,int* np_col,int* my_row,int* my_col);
int numroc_(int *n,int *nb,int *iproc,int *isrcproc,int *nprocs);
/* PBLAS */
void pdgemm_( char *TRANSA,char *TRANSB,int * M,int * N,int * K,double * ALPHA,
double * A,int * IA,int * JA,int * DESCA,double * B,int * IB,int * JB,int * DESCB,
double * BETA,double * C,int * IC,int * JC,int * DESCC );
#define BLOCK_SIZE65
int main(int argc,char* argv[] )
int iam, nprocs;
MPI_Init(&argc,&argv); /* starts MPI */
MPI_Comm_rank(MPI_COMM_WORLD, &iam);
MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
// get done with the ones that are not part of the grid
int blacs_pgrid_size =floor(sqrt(nprocs));
if (iam>=blacs_pgrid_size*blacs_pgrid_size) {
printf("Bye bye world from process %d of %d. BLACS had no place for me...\n",iam,nprocs);
MPI_Finalize();
// start BLACS with square processor grid
if(iam==0)
printf("starting BLACS...");
int ictxt,nprow,npcol,myrow,mycol;
Cblacs_get( -1,0, &ictxt );
Cblacs_gridinit( &ictxt,"C", blacs_pgrid_size, blacs_pgrid_size );
Cblacs_gridinfo( ictxt, &nprow, &npcol, &myrow, &mycol );
if(iam==0)
printf("done.\n");
double timing;
int m,n,k,lm,ln,nbm,nbn,rounds;
int myzero=0,myone=1;
sscanf(argv[1],"%d",&m);
n=m;
k=m;
sscanf(argv[2],"%d",&rounds);
nbm = BLOCK_SIZE;
nbn = BLOCK_SIZE;
lm =numroc_(&m, &nbm, &myrow, &myzero, &nprow);
ln =numroc_(&n, &nbn, &mycol, &myzero, &npcol);
int info;
int *ipiv = new int[lm+nbm+10000000]; //adding a "little" bit of extra space just in case
char ta ='N',tb ='T';
double alpha =1.0, beta =0.0;
double* test1data =new double[lm*ln];
double* test2data =new double[lm*ln];
double* test3data =new double[lm*ln];
for(int i=0;i
test1data=(double)(rand()%100)/10000.0;
int *test1desc =new int[9];
int *test2desc =new int[9];
int *test3desc =new int[9];
test1desc[0] =1; // descriptor type
test1desc[1] = ictxt; // blacs context
test1desc[2] = m; // global number of rows
test1desc[3] = n; // global number of columns
test1desc[4] = nbm; // row block size
test1desc[5] = nbn; // column block size (DEFINED EQUAL THAN ROW BLOCK SIZE)
test1desc[6] = 0; // initial process row(DEFINED 0)
test1desc[7] = 0; // initial process column (DEFINED 0)
test1desc[8] = lm; // leading dimension of local array
memcpy(test2desc,test1desc,9*sizeof(int));
memcpy(test3desc,test1desc,9*sizeof(int));
for(int iter=0;iter
if(iam==0)
printf("iter %i - ",iter);
//test2 = test1
memcpy(test2data,test1data,lm*ln*sizeof(double));
//test3 = test1*test2
timing=MPI_Wtime();
pdgemm_(&ta,&tb,&m,&n,&k,
α,
test1data,&myone,&myone,test1desc,
test2data,&myone,&myone, test2desc,
β,
test3data,&myone,&myone, test3desc);
if(iam==0)
printf(" PDGEMM = %f |",MPI_Wtime()-timing);
//test3 = LU(test3)
timing=MPI_Wtime();
pdgetrf_(&m, &n, test3data, &myone, &myone, test3desc, ipiv, &info);
if(iam==0)
printf(" PDGETRF = %f.\n",MPI_Wtime()-timing);
delete[] ipiv;
delete[] test1data, test2data, test3data;
delete[] test1desc, test2desc, test3desc;
MPI_Finalize();
return 0;
mfactor
Just tested your example using gcc 4.3.2 and mkl 10.2, with openmpi 1.3.3. No segfaults.
mfactor
Also tested with icc 11.1, mkl 10.2, and openmpi 1.3.3. No problems.
