Intel® MPI Library
MPI_File_get_size, max file limit on windows 10
Michael_B_10
It seems the max file size returned is limited to a 4 byte unsigned integer, even though MPI_Offset is 8 bytes. The following program fails in MPI_File_get_size for files larger than 4GB. Is there a way around this?
This is for Windows 10, mpicc.bat for the Intel(R) MPI Library 2018 Update 2 for Windows*
Copyright 2007-2018 Intel Corporation.
Microsoft (R) C/C++ Optimizing Compiler Version 19.14.26430 for x64
Copyright (C) Microsoft Corporation.  All rights reserved.
Attached program shows the issue.
Tony_G_2
Just curious: are you asking this question because you are trying to use HDF5 on Windows10 with files >4Gb? Or it is another use case for which you hit this problem?
Klaus-Dieter_O_Intel
@Michael: Thanks for providing the test code. I have reproduced the issue on Windows 10 and created an internal report. I will keep this forum updated.
Tony_G_2
Id like to add that this is issue is stopping anyone using Intel MPI with HDF5 on windows with large files.
Would appreciate a getaround and/or bug fix for MPI 2017 as well.
The issue was resolved in the now available version Intel(R) MPI Library 2018 Update 4.
