Intel® MPI Library
2275 Discussions
MPI IO problem with intel mpi v. 4.0.1.007 -
Terrence_Liao
We upgrade to Intel compiler V12 with impi 4.0.1.0007, a small mpiio code with simple mpi_file_write_all(...) failed to run with error message "...File locking failed in ADIOI_Set_lock...." Roll the impi back to 4.0.0.028, same code run fine. Any advice? Thanks. -- Terrence Liao
Dmitry_K_Intel2
Hi Terrence,
You probably work on parallel file system. Then you need to set file system explicitly:
Set I_MPI_EXTRA_FILESYSTEM=on and I_MPI_EXTRA_FILESYSTEM_LIST=lustre (or pvfs2 or panfs)
Let me know if you still see the error.
Regards!
Dmitry
Dmitry_K_Intel2
Terrence,
might be this is the same problem as before: http://software.intel.com/en-us/forums/showthread.php?t=71112
Regards!
Dmitry
Terrence_Liao
Dmitry,
It works with -genv I_MPI_EXTRA_FILE_SYSTEM 1 -genv I_MPI_EXTRA_FILE_SYSTEM_LLIST lustre
-- Terrence
