Intel® MPI Library
2292 Discussions
MPI Intel Fortran and Visual Sudio 2022 configuration
fernando1
I'm using visual studio community 2022 and intel oneapi base and HPC toolkits, latest versions. I followed the intel instructions to configure MPI Fortran, as shown abobe:
Configuring a Microsoft Visual Studio* Project
To configure a Microsoft Visual Studio* project with Intel® MPI Library, do the following:
  1. In Microsoft Visual Studio*, create a console application project or open an existing one.
  2. Open the project properties, go to Configuration Properties > Debugging and set the following parameters:
    Command: $(I_MPI_ONEAPI_ROOT)\bin\mpiexec.exe
    Command arguments: -n <processes-number> "$(TargetPath)"
    Environment: PATH=$(I_MPI_ONEAPI_ROOT)\bin\$(ConfigurationName);$(I_MPI_ONEAPI_ROOT)\libfabric\bin;$(PATH)
    NOTE:
    If you have installed the Microsoft Visual Studio* integration, go to Project > Properties > Intel Libraries for oneAPI > Use Intel MPI Library and set it to Yes. You can skip the steps below.
  3. In Configuration Properties > C/C++ or Fortran, as appropriate, set the following parameter:
    Additional Include Directories: $(I_MPI_ONEAPI_ROOT)\include
  4. In Configuration Properties > Linker, set the following parameter:
    Additional Library Directories: $(I_MPI_ONEAPI_ROOT)\lib\$(ConfigurationName);$(I_MPI_ONEAPI_ROOT)\lib
  5. In Configuration Properties > Linker > Input, set the following parameters:
    • For Fortran, set Additional Dependencies: impi.lib
    • For C++, set Additional Dependencies: impi.lib and impicxx.lib
First, I get the the error message:
error #5102 Cannot open include file 'mpif.h'
Second, I don't see an option :
This error is really annoyind and I've been looking for a solution for a long time. I would really appreciate if anyone can help me with this issue.
Thanks in advance,
Fernando Ribeiro
fernando1
Problem solved. Thank you very much !
fernando1
