Intel® MPI Library
MPI_SIZEOF No matching specific subroutine for this generic subroutine call
Jack_S_1
Given the following fortran code:
integer, parameter :: double = kind(1.0d0)
integer :: integerTest
real(double) :: doubleTest
complex(double) :: complexTest
integer :: testSize
integer :: ierr
integerTest = 0
doubleTest = real(0.d0, kind=double)
complexTest = cmplx(0.d0, 0.d0, kind=double)
call MPI_SIZEOF(integerTest, testSize, ierr)
call MPI_SIZEOF(doubleTest, testSize, ierr)
call MPI_SIZEOF(complexTest, testSize, ierr)
I get the error:
error #6285: There is no matching specific subroutine for this generic subroutine call. [MPI_SIZEOF]
on the line
This code compiles and executes with no issue using openmpi. What is the cause of this error? It seems like it's looking for a specific match for the type of complexTest, but the whole point of MPI_SIZEOF is to work generically with nearly any type.
Jack_S_1
Nothing? My code seems to work in MPICH, too. It's Intel MPI that stands out.
Jack_S_1
I should also mention that the code works if I declare complexTest as complex without a kind, but that doesn't help much, since I need double precision complex.
Jack_S_1
And it fails if I declare complexTest as plain double complex.
Jack_S_1
This appears to be a bug in Intel MPI. It looks like the double complex overload is missing. However, with credit to Vladimir F. at StackOverflow, the following solution works:
use iso_fortran_env
testSize = storage_size(complexTest) / character_storage_size
Incidentally, this whole exercise was to properly select the MPI data type to use. In all cases, test size was used in a call to
call MPI_TYPE_MATCH_SIZE(MPI_TYPECLASS_COMPLEX, mpiType, testSize, ierr)
