Intel® MPI Library
2295 Discussions
MPI hangs on intranode communication
LPN2024
I am running a fortran+MPI job on a single server (Xeon(R) Gold 6430, 2 sockets, 32 cores per socket, hyperthreading on). The job:
        1) pid=0: read some data
         2) broadcast data to all processors (not huge, < 150 MB)
         3) each process computes some statistics
         4) each process sends results to pid0
If I launch the job using 32 cores, the job runs quickly; everything works fine.
If I launch requesting 64 cores, the job hangs at step 2.
mpirun -np 32 build/mpi/SparseDemand.exe input.prop
mpirun -np 64 build/mpi/SparseDemand.exe input.prop
I have tried various combinations of I_MPI environment variables and tried tuning, but nothing has improved the situation.
Any thoughts on how to overcome this problem?
Thank you.
TobiasK
@LPN2024  please provide the full output of
I_MPI_DEBUG=10 I_MPI_HYDRA_DEBUG=1 mpirun -np 64 IMB-MPI1
LPN2024
attached is the output of the benchmark
TobiasK
@LPN2024
Since the output seems to be fine, the problem is likely related to your application.
If you develop the application by yourself, you may try to run it with a suitable debugger, and check if everything works as expected. If you do not develop this application, please ask the developers for guidance.
LPN2024
Ok, thank you, I will recheck the application in more detail.
