Intel® MPI Library
2300 Discussions
mpirun failed for oneAPI on Linux Mint
Camps
Hello.
I recently installed Intel oneAPI HPC Toolkit in my Linux Mint box.
(Intel(R) MPI Library, Version 2021.13 Build 20240701 (id: 179630a))
Sourced the environmental variables like:
source /opt/intel/oneapi/setvars.sh
And then compiled the GULP program.
Run an example using:
mpirun -n 2 gulp example1
and got the errors:
Abort(2139023) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Unknown error class, error stack:
MPIR_Init_thread(192)........:
MPID_Init(1665)..............:
MPIDI_OFI_mpi_init_hook(1625):
open_fabric(2726)............:
find_provider(2904)..........: OFI fi_getinfo() failed (ofi_init.c:2904:find_provider:No data available)
Then run as:
mpirun -np 2 gulp example1
and the error was:
The command mpirun --version​ returned:
[mpiexec@VARADERO-LIN] match_arg (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:82): unrecognized argument version​
[mpiexec@VARADERO-LIN] Similar arguments:
[mpiexec@VARADERO-LIN] 	 version
[mpiexec@VARADERO-LIN] HYD_arg_parse_array (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:106): argument matching returned error
[mpiexec@VARADERO-LIN] mpiexec_get_parameters (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1190): error parsing input array
[mpiexec@VARADERO-LIN] main (../../../../../src/pm/i_hydra/mpiexec/mpiexec.c:1725): error parsing parameters
and mpirun -info returned:
HYDRA build details:
    Version:                                 2021.13
    Release Date:                            20240701 (id: 179630a)
    Process Manager:                         pmi
    Bootstrap servers available:             ssh slurm rsh ll sge pbs pbsdsh pdsh srun lsf blaunch qrsh fork
    Resource management kernels available:   slurm ll lsf sge pbs cobalt
All the calculations are run in my notebook:
OS: Linux Mint 22 x86_64
Host: Dell G15 5530
Kernel: 6.8.0-40-generic
Uptime: 2 hours, 21 mins
Packages: 3115 (dpkg), 7 (flatpak)
Shell: bash 5.2.21
Resolution: 1920x1080
DE: Cinnamon 6.2.9
WM: Mutter (Muffin)
WM Theme: Mint-L-Dark (Mint-Y)
Theme: Mint-L-Dark [GTK2/3]
Icons: Mint-L [GTK2/3]
Terminal: gnome-terminal
CPU: 13th Gen Intel i7-13650HX (20) @ 4.700GHz
GPU: Intel Raptor Lake-S UHD Graphics
GPU: NVIDIA GeForce RTX 4050 Max-Q / Mobile
Memory: 11651MiB / 31778MiB
lscpu returned:
Architecture:                         x86_64
CPU op-mode(s):                       32-bit, 64-bit
Address sizes:                        39 bits physical, 48 bits virtual
Byte Order:                           Little Endian
CPU(s):                               20
On-line CPU(s) list:                  0-19
Vendor ID:                            GenuineIntel
Model name:                           13th Gen Intel(R) Core(TM) i7-13650HX
CPU family:                           6
Model:                                183
Thread(s) per core:                   2
Core(s) per socket:                   14
Socket(s):                            1
Stepping:                             1
CPU(s) scaling MHz:                   28%
CPU max MHz:                          4900.0000
CPU min MHz:                          800.0000
BogoMIPS:                             5606.40
Flags:                                fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid rdseed adx smap clflushopt clwb intel_pt sha_ni xsaveopt xsavec xgetbv1 xsaves split_lock_detect user_shstk avx_vnni dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp hwp_pkg_req hfi vnmi umip pku ospke waitpkg gfni vaes vpclmulqdq rdpid movdiri movdir64b fsrm md_clear serialize arch_lbr ibt flush_l1d arch_capabilities
Virtualization:                       VT-x
L1d cache:                            544 KiB (14 instances)
L1i cache:                            704 KiB (14 instances)
L2 cache:                             11.5 MiB (8 instances)
L3 cache:                             24 MiB (1 instance)
NUMA node(s):                         1
NUMA node0 CPU(s):                    0-19
Vulnerability Gather data sampling:   Not affected
Vulnerability Itlb multihit:          Not affected
Vulnerability L1tf:                   Not affected
Vulnerability Mds:                    Not affected
Vulnerability Meltdown:               Not affected
Vulnerability Mmio stale data:        Not affected
Vulnerability Reg file data sampling: Mitigation; Clear Register File
Vulnerability Retbleed:               Not affected
Vulnerability Spec rstack overflow:   Not affected
Vulnerability Spec store bypass:      Mitigation; Speculative Store Bypass disabled via prctl
Vulnerability Spectre v1:             Mitigation; usercopy/swapgs barriers and __user pointer sanitization
Vulnerability Spectre v2:             Mitigation; Enhanced / Automatic IBRS; IBPB conditional; RSB filling; PBRSB-eIBRS SW sequence; BHI BHI_DIS_S
Vulnerability Srbds:                  Not affected
Vulnerability Tsx async abort:        Not affected
and fi_info -l returned:
psm2:
    version: 120.10
mlx:
    version: 1.4
psm3:
    version: 706.0
verbs:
    version: 120.10
verbs:
    version: 120.10
ofi_rxm:
    version: 120.10
tcp:
    version: 120.10
shm:
    version: 120.10
ofi_hook_noop:
    version: 120.10
off_coll:
    version: 120.10
Any help is highly appreciated.
TobiasK
Can you please provide the output of
I_MPI_DEBUG=10 I_MPI_HYDRA_DEBUG=1 mpirun -np 2 IMB-MPI1
Camps
Here it is:
[mpiexec@VARADERO-LIN] Launch arguments: /opt/intel/oneapi/mpi/2021.13/bin//hydra_bstrap_proxy --upstream-host VARADERO-LIN --upstream-port 41533 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.13/bin/ --topolib hwloc --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/oneapi/mpi/2021.13/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@VARADERO-LIN] PMI response: cmd=response_to_init pmi_version=1 pmi_subversion=1 rc=0
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get_maxes
[proxy:0:0@VARADERO-LIN] PMI response: cmd=maxes kvsname_max=256 keylen_max=64 vallen_max=4096
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get_appnum
[proxy:0:0@VARADERO-LIN] PMI response: cmd=appnum appnum=0
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get_my_kvsname
[proxy:0:0@VARADERO-LIN] PMI response: cmd=my_kvsname kvsname=kvs_26985_0
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=init pmi_version=1 pmi_subversion=1
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=get_maxes
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=get_appnum
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=get_my_kvsname
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get kvsname=kvs_26985_0 key=PMI_process_mapping
[proxy:0:0@VARADERO-LIN] PMI response: cmd=get_result rc=0 msg=success value=(vector,(0,1,2))
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=get kvsname=kvs_26985_0 key=PMI_process_mapping
[0] MPI startup(): Intel(R) MPI Library, Version 2021.13  Build 20240701 (id: 179630a)
[0] MPI startup(): Copyright (C) 2003-2024 Intel Corporation.  All rights reserved.
[0] MPI startup(): library kind: release
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=barrier_in
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=put kvsname=kvs_26985_0 key=-bcast-1-0 value=2F6465762F73686D2F496E74656C5F4D50495F716D514C4B66
[proxy:0:0@VARADERO-LIN] PMI response: cmd=put_result rc=0 msg=success
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=barrier_in
[proxy:0:0@VARADERO-LIN] PMI response: cmd=barrier_out
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get kvsname=kvs_26985_0 key=-bcast-1-0
[proxy:0:0@VARADERO-LIN] PMI response: cmd=get_result rc=0 msg=success value=2F6465762F73686D2F496E74656C5F4D50495F716D514C4B66
[0] MPI startup(): libfabric loaded: libfabric.so.1
[0] MPI startup(): libfabric version: 1.20.1-impi
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=abort exitcode=2139023
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=abort exitcode=2139023
Camps
Hi @TobiasK .
I did a test compiling/running a simple hello_word example, and the errors running it are the same, so, I am afraid this is not a GULP problem.
My hello_world code:
PROGRAM hello_world_mpi
include 'mpif.h'
integer process_Rank, size_Of_Cluster, ierror, tag
call MPI_INIT(ierror)
call MPI_COMM_SIZE(MPI_COMM_WORLD, size_Of_Cluster, ierror)
call MPI_COMM_RANK(MPI_COMM_WORLD, process_Rank, ierror)
print *, 'Hello World from process: ', process_Rank, 'of ', size_Of_Cluster
call MPI_FINALIZE(ierror)
END PROGRAM
Compile it with
mpiifx hello_world_mpi.f90 -o hello_world_mpi.exe
and got:
Abort(2139535) on node 0 (rank 0 in comm 0): Fatal error in PMPI_Init: Unknown error class, error stack:
MPIR_Init_thread(193)........:
MPID_Init(1715)..............:
MPIDI_OFI_mpi_init_hook(1633):
open_fabric(2739)............:
find_provider(2924)..........: OFI fi_getinfo() failed (ofi_init.c:2924:find_provider:No data available)
TobiasK
@Camps Please look at my last post and reply to that
TobiasK
Please try with:
I_MPI_FABRICS=shm mpirun ...
Camps
icamps@VARADERO-LIN:Examples$ I_MPI_FABRICS=shm mpirun -np 2 gulp example1
Abort(134828037) on node 1 (rank 1 in comm 0): Fatal error in PMPI_Comm_rank: Unknown error class, error stack:
PMPI_Comm_rank(106): MPI_Comm_rank(comm=0x0, rank=0x7ffe819c927c) failed
PMPI_Comm_rank(63).: Invalid communicator
TobiasK
@Camps  I am afraid I cannont help with GULP:
GULP is available for free for academic use by anyone with a valid University email account. To access the code please go to the appropriate tab and "register". The code is provided "as is" and without support. Any questions regarding the use of the code can be posted at the user forum if not already covered in previous topics. Bug reports and registration queries can be sent to gulpcode at curtin.edu.au, and we will try to respond as soon as is possible.
you may ask in the forum mentioned.
Please provide the output of:
I_MPI_FABRICS=shm I_MPI_DEBUG=10 I_MPI_HYDRA_DEBUG=1 mpirun -np 2 IMB-MPI1
if that works you need to ask someone with access to GULP
Camps
Hi @TobiasK
Below is the output.
The first thing I did was to make a post on the GULP forum. Unfortunately, Julian (the GULP developer) cannot help with this issue.
[mpiexec@VARADERO-LIN] Launch arguments: /opt/intel/oneapi/mpi/2021.14/bin//hydra_bstrap_proxy --upstream-host VARADERO-LIN --upstream-port 35289 --pgid 0 --launcher ssh --launcher-number 0 --base-path /opt/intel/oneapi/mpi/2021.14/bin/ --tree-width 16 --tree-level 1 --time-left -1 --launch-type 2 --debug --proxy-id 0 --node-id 0 --subtree-size 1 --upstream-fd 7 /opt/intel/oneapi/mpi/2021.14/bin//hydra_pmi_proxy --usize -1 --auto-cleanup 1 --abort-signal 9
[proxy:0:0@VARADERO-LIN] PMI response: cmd=my_kvsname kvsname=kvs_8807_0
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=get kvsname=kvs_8807_0 key=PMI_process_mapping
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get kvsname=kvs_8807_0 key=PMI_process_mapping
[0] MPI startup(): Intel(R) MPI Library, Version 2021.14  Build 20240911 (id: b3fc682)
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=put kvsname=kvs_8807_0 key=-bcast-1-0 value=2F6465762F73686D2F496E74656C5F4D50495F353952764A43
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=get kvsname=kvs_8807_0 key=-bcast-1-0
[proxy:0:0@VARADERO-LIN] PMI response: cmd=get_result rc=0 msg=success value=2F6465762F73686D2F496E74656C5F4D50495F353952764A43
[0] MPI startup(): shm segment size (1068 MB per rank) * (2 local ranks) = 2136 MB total
[0] MPI startup(): max number of MPI_Request per vci: 67108864 (pools: 1)
[0] MPI startup(): Load tuning file: "/opt/intel/oneapi/mpi/2021.14/opt/mpi/etc/tuning_skx_shm.dat"
[0] MPI startup(): threading: mode: direct
[0] MPI startup(): threading: vcis: 1
[0] MPI startup(): threading: app_threads: -1
[0] MPI startup(): threading: runtime: generic
[0] MPI startup(): threading: progress_threads: 0
[0] MPI startup(): threading: async_progress: 0
[0] MPI startup(): threading: async_progress coll split: 0
[0] MPI startup(): threading: lock_level: global
[0] MPI startup(): tag bits available: 30 (TAG_UB value: 1073741823)
[0] MPI startup(): source bits available: 0 (Maximal number of rank: 0)
[0] MPI startup(): ===== CPU pinning =====
[0] MPI startup(): Rank    Pid      Node name     Pin cpu
[0] MPI startup(): 0       8812     VARADERO-LIN  {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19}
[0] MPI startup(): 1       8813     VARADERO-LIN  {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19}
[0] MPI startup(): I_MPI_ROOT=/opt/intel/oneapi/mpi/2021.14
[0] MPI startup(): ONEAPI_ROOT=/opt/intel/oneapi
[0] MPI startup(): I_MPI_MPIRUN=mpirun
[0] MPI startup(): I_MPI_BIND_WIN_ALLOCATE=localalloc
[0] MPI startup(): I_MPI_HYDRA_DEBUG=1
[0] MPI startup(): I_MPI_HYDRA_TOPOLIB=hwloc
[0] MPI startup(): I_MPI_RETURN_WIN_MEM_NUMA=-1
[0] MPI startup(): I_MPI_INTERNAL_MEM_POLICY=default
[0] MPI startup(): I_MPI_FABRICS=shm
[0] MPI startup(): I_MPI_DEBUG=10
#    Intel(R) MPI Benchmarks 2021.8, MPI-1 part
# Date                  : Tue Nov  5 09:55:55 2024
# Machine               : x86_64
# System                : Linux
# Release               : 6.8.0-40-generic
# Version               : #40-Ubuntu SMP PREEMPT_DYNAMIC Fri Jul  5 10:34:03 UTC 2024
# MPI Version           : 3.1
# MPI Thread Environment:
# Calling sequence was:
# IMB-MPI1
# Minimum message length in bytes:   0
# Maximum message length in bytes:   4194304
# MPI_Datatype                   :   MPI_BYTE
# MPI_Datatype for reductions    :   MPI_FLOAT
# MPI_Op                         :   MPI_SUM
# List of Benchmarks to run:
# PingPong
# PingPing
# Sendrecv
# Exchange
# Allreduce
# Reduce
# Reduce_local
# Reduce_scatter
# Reduce_scatter_block
# Allgather
# Allgatherv
# Gather
# Gatherv
# Scatter
# Scatterv
# Alltoall
# Alltoallv
# Bcast
# Barrier
# Benchmarking PingPong
# #processes = 2
       #bytes #repetitions      t[usec]   Mbytes/sec
            0         1000         0.36         0.00
            1         1000         0.37         2.71
            2         1000         0.32         6.34
            4         1000         0.27        14.77
            8         1000         0.25        32.51
           16         1000         0.22        74.25
           32         1000         0.19       165.05
           64         1000         0.18       352.45
          128         1000         0.17       772.28
          256         1000         0.16      1607.62
          512         1000         0.22      2310.16
         1024         1000         0.29      3553.83
         2048         1000         0.38      5404.71
         4096         1000         0.52      7807.74
         8192         1000         0.89      9169.67
        16384         1000         1.56     10532.23
        32768         1000         2.57     12743.93
        65536          640         4.04     16238.29
       131072          320         6.77     19374.62
       262144          160         9.43     27805.87
       524288           80        20.63     25419.79
      1048576           40        49.24     21297.16
      2097152           20        95.06     22062.18
      4194304           10       181.56     23101.08
# Benchmarking PingPing
# #processes = 2
            0         1000         0.17         0.00
            1         1000         0.18         5.59
            2         1000         0.16        12.36
            4         1000         0.16        25.02
            8         1000         0.16        49.88
           16         1000         0.16        97.19
           32         1000         0.16       198.68
           64         1000         0.17       386.28
          128         1000         0.18       718.09
          256         1000         0.19      1335.45
          512         1000         0.26      1938.36
         1024         1000         0.32      3242.76
         2048         1000         0.40      5122.62
         4096         1000         0.54      7550.11
         8192         1000         0.93      8831.94
        16384         1000         1.59     10329.53
        32768         1000         2.18     14998.42
        65536          640         4.10     16003.13
       131072          320         6.54     20036.65
       262144          160        12.67     20684.85
       524288           80        36.43     14391.15
      1048576           40        83.19     12604.03
      2097152           20       170.84     12275.77
      4194304           10       308.29     13604.87
# Benchmarking Sendrecv
# #processes = 2
       #bytes #repetitions  t_min[usec]  t_max[usec]  t_avg[usec]   Mbytes/sec
            0         1000         0.15         0.15         0.15         0.00
            1         1000         0.16         0.16         0.16        12.70
            2         1000         0.16         0.16         0.16        24.67
            4         1000         0.16         0.16         0.16        48.53
            8         1000         0.16         0.16         0.16       100.61
           16         1000         0.16         0.16         0.16       200.93
           32         1000         0.16         0.16         0.16       402.49
           64         1000         0.17         0.17         0.17       759.61
          128         1000         0.17         0.17         0.17      1487.36
          256         1000         0.19         0.19         0.19      2726.17
          512         1000         0.24         0.24         0.24      4261.52
         1024         1000         0.30         0.30         0.30      6921.19
         2048         1000         0.38         0.38         0.38     10853.89
         4096         1000         0.55         0.55         0.55     14950.89
         8192         1000         0.91         0.91         0.91     18094.06
        16384         1000         1.59         1.59         1.59     20591.82
        32768         1000         2.15         2.15         2.15     30497.38
        65536          640         4.03         4.04         4.03     32483.56
       131072          320         6.67         6.68         6.67     39261.98
       262144          160        12.58        12.58        12.58     41684.46
       524288           80        38.13        38.37        38.25     27328.95
      1048576           40        82.88        82.88        82.88     25303.14
      2097152           20       192.53       192.62       192.58     21774.88
      4194304           10       564.02       564.05       564.04     14872.08
# Benchmarking Exchange
# #processes = 2
            0         1000         0.46         0.46         0.46         0.00
            1         1000         0.45         0.45         0.45         8.85
            2         1000         0.47         0.47         0.47        16.85
            4         1000         0.49         0.49         0.49        32.91
            8         1000         0.49         0.49         0.49        65.82
           16         1000         0.49         0.49         0.49       131.73
           32         1000         0.48         0.48         0.48       265.34
           64         1000         0.51         0.51         0.51       501.87
          128         1000         0.52         0.52         0.52       983.99
          256         1000         0.52         0.52         0.52      1955.01
          512         1000         0.70         0.70         0.70      2908.69
         1024         1000         0.91         0.91         0.91      4523.90
         2048         1000         1.11         1.11         1.11      7405.37
         4096         1000         1.61         1.61         1.61     10148.14
         8192         1000         2.22         2.22         2.22     14742.76
        16384         1000         3.58         3.58         3.58     18329.77
        32768         1000         4.55         4.55         4.55     28799.56
        65536          640         8.14         8.14         8.14     32213.36
       131072          320        13.22        13.22        13.22     39656.49
       262144          160        29.84        29.87        29.85     35110.22
       524288           80        80.84        80.97        80.90     25900.15
      1048576           40       169.03       169.04       169.03     24812.95
      2097152           20       346.37       346.47       346.42     24211.36
      4194304           10       648.29       648.81       648.55     25858.29
# Benchmarking Allreduce
# #processes = 2
            0         1000         0.02         0.02         0.02
            4         1000         0.23         0.24         0.23
            8         1000         0.24         0.24         0.24
           16         1000         0.23         0.23         0.23
           32         1000         0.23         0.24         0.23
           64         1000         0.27         0.33         0.30
          128         1000         0.26         0.33         0.30
          256         1000         0.28         0.34         0.31
          512         1000         0.33         0.40         0.37
         1024         1000         0.38         0.46         0.42
         2048         1000         0.49         0.57         0.53
         4096         1000         0.71         0.79         0.75
         8192         1000         1.17         1.25         1.21
        16384         1000         2.22         2.26         2.24
        32768         1000         3.73         3.78         3.75
        65536          640         5.09         5.11         5.10
       131072          320         9.48         9.49         9.49
       262144          160        15.70        15.78        15.74
       524288           80        35.77        36.50        36.14
      1048576           40        89.30        89.88        89.59
      2097152           20       205.96       205.99       205.97
      4194304           10       569.25       576.56       572.91
# Benchmarking Reduce
# #processes = 2
            4         1000         0.08         0.24         0.16
            8         1000         0.08         0.21         0.14
           16         1000         0.12         0.26         0.19
           32         1000         0.08         0.18         0.13
           64         1000         0.12         0.27         0.19
          128         1000         0.13         0.27         0.20
          256         1000         0.14         0.32         0.23
          512         1000         0.08         0.33         0.21
         1024         1000         0.09         0.41         0.25
         2048         1000         0.09         0.53         0.31
         4096         1000         0.18         0.76         0.47
         8192         1000         0.58         1.18         0.88
        16384         1000         1.15         2.49         1.82
        32768         1000         2.94         4.25         3.59
        65536          640         2.88         6.14         4.51
       131072          320         3.57         8.54         6.06
       262144          160        13.28        16.72        15.00
       524288           80        13.20        31.36        22.28
      1048576           40        33.55        72.56        53.05
      2097152           20        81.28       143.82       112.55
      4194304           10       167.45       286.28       226.87
# Benchmarking Reduce_local
# #processes = 2
            4         1000         0.02         0.02         0.02
            8         1000         0.02         0.02         0.02
           16         1000         0.02         0.02         0.02
           32         1000         0.02         0.02         0.02
           64         1000         0.02         0.02         0.02
          128         1000         0.02         0.02         0.02
          256         1000         0.02         0.02         0.02
          512         1000         0.02         0.02         0.02
         1024         1000         0.03         0.04         0.03
         2048         1000         0.05         0.06         0.06
         4096         1000         0.07         0.10         0.09
         8192         1000         0.13         0.15         0.14
        16384         1000         0.23         0.25         0.24
        32768         1000         0.61         0.62         0.62
        65536          640         1.20         1.21         1.20
       131072          320         2.35         2.36         2.36
       262144          160         4.88         4.88         4.88
       524288           80         9.55         9.57         9.56
      1048576           40        39.26        39.59        39.43
      2097152           20        81.46        81.51        81.49
      4194304           10       162.40       162.58       162.49
# Benchmarking Reduce_scatter
# #processes = 2
            0         1000         0.06         0.08         0.07
            4         1000         0.30         0.36         0.33
            8         1000         0.29         0.36         0.33
           16         1000         0.31         0.38         0.34
           32         1000         0.32         0.38         0.35
           64         1000         0.32         0.38         0.35
          128         1000         0.34         0.40         0.37
          256         1000         0.36         0.41         0.39
          512         1000         0.41         0.47         0.44
         1024         1000         0.46         0.53         0.50
         2048         1000         0.57         0.65         0.61
         4096         1000         0.85         0.92         0.88
         8192         1000         1.57         1.65         1.61
        16384         1000         2.86         2.97         2.92
        32768         1000         4.38         4.47         4.42
        65536          640        17.29        18.41        17.85
       131072          320        10.99        11.92        11.46
       262144          160        26.46        26.93        26.70
       524288           80        71.03        73.72        72.37
      1048576           40       163.52       169.76       166.64
      2097152           20       342.67       347.95       345.31
      4194304           10       815.82       837.96       826.89
# Benchmarking Reduce_scatter_block
# #processes = 2
            4         1000         0.28         0.34         0.31
            8         1000         0.28         0.34         0.31
           16         1000         0.28         0.34         0.31
           32         1000         0.28         0.34         0.31
           64         1000         0.29         0.35         0.32
          128         1000         0.30         0.36         0.33
          256         1000         0.32         0.38         0.35
          512         1000         0.42         0.47         0.44
         1024         1000         0.44         0.51         0.47
         2048         1000         0.54         0.62         0.58
         4096         1000         0.82         0.89         0.85
         8192         1000         1.60         1.66         1.63
        16384         1000         3.00         3.08         3.04
        32768         1000         4.31         4.47         4.39
        65536          640         8.21         8.60         8.40
       131072          320        15.10        15.14        15.12
       262144          160        26.11        26.12        26.11
       524288           80        71.25        71.47        71.36
      1048576           40       166.80       170.55       168.68
      2097152           20       335.26       341.19       338.23
      4194304           10       790.99       791.86       791.42
# Benchmarking Allgather
# #processes = 2
            1         1000         0.22         0.29         0.26
            2         1000         0.22         0.28         0.25
            4         1000         0.23         0.30         0.27
            8         1000         0.21         0.28         0.25
           16         1000         0.22         0.28         0.25
           32         1000         0.22         0.28         0.25
           64         1000         0.23         0.28         0.26
          128         1000         0.23         0.29         0.26
          256         1000         0.25         0.32         0.28
          512         1000         0.30         0.38         0.34
         1024         1000         0.37         0.40         0.39
         2048         1000         0.45         0.49         0.47
         4096         1000         0.64         0.68         0.66
         8192         1000         1.35         1.42         1.38
        16384         1000         1.96         2.01         1.98
        32768         1000         2.75         2.83         2.79
        65536          640         5.09         5.09         5.09
       131072          320         8.37         8.43         8.40
       262144          160        17.31        17.46        17.39
       524288           80        55.58        55.81        55.70
      1048576           40       124.00       124.18       124.09
      2097152           20       266.23       266.41       266.32
      4194304           10       480.44       480.53       480.49
# Benchmarking Allgatherv
# #processes = 2
            0         1000         0.05         0.06         0.06
            1         1000         0.27         0.33         0.30
            2         1000         0.26         0.33         0.29
            4         1000         0.26         0.32         0.29
            8         1000         0.26         0.33         0.29
           16         1000         0.27         0.33         0.30
           32         1000         0.27         0.33         0.30
           64         1000         0.28         0.34         0.31
          128         1000         0.31         0.37         0.34
          256         1000         0.31         0.37         0.34
          512         1000         0.37         0.43         0.40
         1024         1000         0.41         0.48         0.44
         2048         1000         0.51         0.58         0.54
         4096         1000         0.80         0.85         0.83
         8192         1000         1.41         1.48         1.45
        16384         1000         2.46         2.55         2.50
        32768         1000         3.82         3.84         3.83
        65536          640         7.06         7.10         7.08
       131072          320        12.49        12.50        12.49
       262144          160        17.99        18.16        18.08
       524288           80        55.38        55.62        55.50
      1048576           40       123.08       123.44       123.26
      2097152           20       247.70       247.80       247.75
      4194304           10       475.62       475.70       475.66
# Benchmarking Gather
# #processes = 2
            1         1000         0.12         0.26         0.19
            2         1000         0.12         0.28         0.20
            4         1000         0.12         0.29         0.21
            8         1000         0.12         0.26         0.19
           16         1000         0.12         0.29         0.21
           32         1000         0.12         0.26         0.19
           64         1000         0.12         0.27         0.20
          256         1000         0.13         0.29         0.21
          512         1000         0.20         0.42         0.31
         1024         1000         0.21         0.50         0.35
         2048         1000         0.28         0.65         0.47
         4096         1000         0.35         0.90         0.63
         8192         1000         0.49         1.55         1.02
        16384         1000         0.79         2.06         1.42
        32768         1000         1.31         3.10         2.20
        65536          640         2.66         4.79         3.73
       131072          320         3.03         7.21         5.12
       262144          160         5.90        13.10         9.50
       524288           80        11.94        41.18        26.56
      1048576           40        32.61        82.53        57.57
      2097152           20        80.98       163.79       122.38
      4194304           10       244.19       281.78       262.99
# Benchmarking Gatherv
# #processes = 2
            0         1000         0.16         0.17         0.17
            1         1000         0.38         0.42         0.40
            2         1000         0.38         0.43         0.40
            4         1000         0.38         0.43         0.40
            8         1000         0.39         0.44         0.41
           16         1000         0.38         0.43         0.40
           32         1000         0.39         0.44         0.41
           64         1000         0.40         0.44         0.42
          128         1000         0.39         0.44         0.42
          256         1000         0.40         0.44         0.42
          512         1000         0.55         0.58         0.57
         1024         1000         0.63         0.67         0.65
         2048         1000         0.75         0.78         0.77
         4096         1000         0.96         1.00         0.98
         8192         1000         1.38         1.40         1.39
        16384         1000         2.04         2.05         2.05
        32768         1000         3.06         3.09         3.08
        65536          640         4.58         4.60         4.59
       131072          320         7.38         7.40         7.39
       262144          160        13.47        13.49        13.48
       524288           80        40.88        40.97        40.93
      1048576           40        83.08        83.13        83.10
      2097152           20       164.98       165.03       165.01
      4194304           10       282.31       282.47       282.39
# Benchmarking Scatter
# #processes = 2
            1         1000         0.12         0.15         0.13
            2         1000         0.12         0.14         0.13
            4         1000         0.12         0.14         0.13
            8         1000         0.12         0.15         0.14
           16         1000         0.12         0.14         0.13
           32         1000         0.12         0.15         0.14
           64         1000         0.12         0.16         0.14
          128         1000         0.12         0.16         0.14
          256         1000         0.12         0.16         0.14
          512         1000         0.22         0.29         0.26
         1024         1000         0.23         0.34         0.28
         2048         1000         0.28         0.45         0.36
         4096         1000         0.35         0.68         0.51
         8192         1000         0.51         1.16         0.84
        16384         1000         0.97         1.51         1.24
        32768         1000         1.75         3.46         2.60
        65536          640         3.55         5.44         4.50
       131072          320         7.12         9.18         8.15
       262144          160        11.42        14.45        12.94
       524288           80        38.30        40.21        39.25
      1048576           40        85.24        87.36        86.30
      2097152           20       169.80       172.92       171.36
      4194304           10       324.24       326.30       325.27
# Benchmarking Scatterv
# #processes = 2
            0         1000         0.21         0.27         0.24
            1         1000         0.22         0.28         0.25
            2         1000         0.22         0.26         0.24
            4         1000         0.22         0.27         0.24
            8         1000         0.23         0.28         0.26
           16         1000         0.23         0.27         0.25
           32         1000         0.23         0.27         0.25
           64         1000         0.23         0.27         0.25
          128         1000         0.23         0.28         0.25
          256         1000         0.24         0.29         0.27
          512         1000         0.33         0.36         0.35
         1024         1000         0.33         0.41         0.37
         2048         1000         0.39         0.55         0.47
         4096         1000         0.47         0.77         0.62
         8192         1000         0.66         1.22         0.94
        16384         1000         1.16         1.63         1.39
        32768         1000         2.02         2.48         2.25
        65536          640         3.92         3.98         3.95
       131072          320         6.69         7.46         7.07
       262144          160         9.73        11.67        10.70
       524288           80        30.72        43.10        36.91
      1048576           40        49.33        85.53        67.43
      2097152           20        93.93       170.73       132.33
      4194304           10       176.21       326.69       251.45
# Benchmarking Alltoall
# #processes = 2
            1         1000         0.41         0.42         0.42
            2         1000         0.42         0.43         0.42
            4         1000         0.41         0.42         0.41
            8         1000         0.41         0.42         0.41
           16         1000         0.42         0.43         0.42
           32         1000         0.41         0.42         0.41
           64         1000         0.44         0.45         0.44
          128         1000         0.45         0.48         0.46
          256         1000         0.45         0.47         0.46
          512         1000         0.52         0.58         0.55
         1024         1000         0.57         0.62         0.59
         2048         1000         0.67         0.72         0.70
         4096         1000         0.84         0.89         0.87
         8192         1000         1.28         1.32         1.30
        16384         1000         1.65         1.66         1.66
        32768         1000         2.88         2.90         2.89
        65536          640         5.39         5.40         5.39
       131072          320         8.65         8.98         8.82
       262144          160        20.96        20.98        20.97
       524288           80        56.93        57.13        57.03
      1048576           40       123.72       123.85       123.79
      2097152           20       258.11       260.91       259.51
      4194304           10       535.03       535.15       535.09
# Benchmarking Alltoallv
# #processes = 2
            0         1000         0.40         0.41         0.41
            1         1000         0.83         0.84         0.83
            2         1000         0.82         0.83         0.82
            4         1000         0.83         0.83         0.83
            8         1000         0.84         0.85         0.84
           16         1000         0.81         0.82         0.81
           32         1000         0.83         0.84         0.84
           64         1000         0.84         0.84         0.84
          128         1000         0.85         0.85         0.85
          256         1000         0.88         0.88         0.88
          512         1000         0.90         0.96         0.93
         1024         1000         0.96         1.03         0.99
         2048         1000         1.17         1.24         1.20
         4096         1000         1.21         1.28         1.25
         8192         1000         1.69         1.74         1.71
        16384         1000         2.05         2.07         2.06
        32768         1000         3.26         3.29         3.28
        65536          640         5.58         5.61         5.59
       131072          320         8.92         8.93         8.92
       262144          160        21.56        21.65        21.61
       524288           80        59.73        90.06        74.89
      1048576           40       131.82       195.50       163.66
      2097152           20       259.41       261.86       260.63
      4194304           10       535.77       535.85       535.81
# Benchmarking Bcast
# #processes = 2
            0         1000         0.01         0.01         0.01
            1         1000         0.10         0.11         0.11
            2         1000         0.11         0.11         0.11
            4         1000         0.11         0.11         0.11
            8         1000         0.11         0.11         0.11
           16         1000         0.12         0.12         0.12
           32         1000         0.11         0.11         0.11
           64         1000         0.11         0.13         0.12
          128         1000         0.11         0.13         0.12
          256         1000         0.11         0.13         0.12
          512         1000         0.11         0.15         0.13
         1024         1000         0.12         0.25         0.18
         2048         1000         0.12         0.33         0.23
         4096         1000         0.18         0.52         0.35
         8192         1000         0.27         0.90         0.58
        16384         1000         0.42         1.66         1.04
        32768         1000         0.79         2.68         1.73
        65536          640         1.71         3.81         2.76
       131072          320         3.30         6.40         4.85
       262144          160         6.92        10.33         8.62
       524288           80        14.23        18.66        16.45
      1048576           40        33.27        42.50        37.88
      2097152           20        89.77        93.12        91.44
      4194304           10       176.36       179.56       177.96
# Benchmarking Barrier
# #processes = 2
         1000         0.18         0.18         0.18
# All processes entering MPI_Finalize
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 6: cmd=finalize
[proxy:0:0@VARADERO-LIN] PMI response: cmd=finalize_ack
[proxy:0:0@VARADERO-LIN] pmi cmd from fd 9: cmd=finalize
