Intel® MPI Library
2284 Discussions
MPI startup(): dapl fabric is not available and fallback fabric is not enabled
Vijay_Amirtharaj_A
I am getting following error message.mpdboot is started in nodes.
wile running intel benchmark test.this error is coming.
[30] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[17] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[16] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[22] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[25] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[26] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[28] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[29] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[46] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[21] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[20] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[19] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[23] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[18] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[41] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[40] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[45] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[44] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[42] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[43] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[35] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[47] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[73] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[76] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[71] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[70] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[77] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[78] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[79] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[13] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[15] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[0] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[9] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[4] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[5] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[14] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[1] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[11] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[12] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[6] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[8] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[10] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[3] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[7] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[2] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[143] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[136] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[139] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[140] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[138] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[141] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[142] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
[137] MPI startup(): dapl fabric is not available and fallback fabric is not enabled
rank 143 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 143: return code 254
rank 142 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 142: return code 254
rank 141 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 141: return code 254
rank 140 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 140: return code 254
rank 139 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 139: return code 254
rank 138 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 138: return code 254
rank 79 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 79: return code 254
rank 76 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 76: return code 254
rank 73 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 73: killed by signal 9
rank 46 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 46: return code 254
rank 45 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 45: return code 254
rank 44 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 44: return code 254
rank 43 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 43: return code 254
rank 42 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 42: return code 254
rank 41 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 41: return code 254
rank 30 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 30: return code 254
rank 25 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 25: return code 254
rank 22 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 22: killed by signal 9
rank 21 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 21: return code 254
rank 17 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 17: killed by signal 9
rank 16 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 16: return code 254
rank 15 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 15: killed by signal 9
rank 13 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 13: return code 254
rank 12 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 12: return code 254
rank 10 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 10: return code 254
rank 9 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 9: return code 254
rank 8 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 8: return code 254
rank 6 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 6: return code 254
rank 4 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 4: return code 254
rank 3 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 3: return code 254
rank 0 in job 1  taavare.tuecms.com_44209   caused collective abort of all ranks
  exit status of rank 0: return code 254
James_T_Intel
Hi Vijay,
Since this is a duplicate of http://software.intel.com/en-us/forums/topic/381521, I will respond there.
Sincerely,
James Tullos
Technical Consulting Engineer
Intel® Cluster Tools
