Intel® MPI Library
Mpi code not running
Lamine06F
I have a simple code and here isit :
program MPI_program
    use MPI
    implicit none
    ! Data declarations for MPI
INTEGER :: ierr   ! error signal variable. Standard value = 0
INTEGER :: rank   ! process ID / Number
INTEGER :: nprocs ! number of processors
    ! Initialize MPI
! Initialize subroutine
CALL MPI_INIT(ierr)
! Setup Communicator sizé
CALL MPI_COMM_SIZE(MPI_COMM_WORLD, nprocs, ierr)
! Setup ranks/IDs for each process
CALL MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr)
! Type the main code
print *, 'Hello World ! I am process', rank, ' of ', nprocs, 'Process(es)'
! Finalize MPI
! Finalize subroutine
CALL MPI_FINALIZE(ierr)
    end program MPI_program
and Ihave followed all the instruction given here https://www.intel.com/content/www/us/en/docs/mpi-library/developer-guide-windows/2021-9/configuring-a-microsoft-visual-studio-project.html to config it. At the end, when I hit ctrl+F5 to build it, I have this error :
Erreur fatal error LNK1181: impossible d'ouvrir le fichier en entr‚e 'impi.lib' LINK.
Please any clue  about what is wrong
VeenaJ_Intel
Thanks for posting in Intel communities.
I have attempted to recreate the problem using the code you provided, and I am pleased to inform you that it compiles without any issues.
To assist you further, I have attached the following for your reference:
  • Screenshots of the Configuration Settings
  • Project Files
  • Compilation Screenshot
It is worth noting that during my investigation, I discovered that the issue can indeed be recreated if the following setting is not correctly configured or left empty:
Properties -> Linker -> General -> Additional Library Directories
Please configure it with the path "$(I_MPI_ONEAPI_ROOT)\lib\$(ConfigurationName);$(I_MPI_ONEAPI_ROOT)\lib".
I have included a screenshot highlighting the problem when this setting is not correctly configured.
If the issue persists on your end despite using the provided configuration settings, please provide the following details:
  • Your Project Files
  • Screenshots of Configuration Settings
  • Output of "lscpu" Command
  • Operating System Version and Details
  • One API Toolkit Version
  • Visual Studio Version
With the above mentioned details, we can perform a detailed analysis of the issue.
Thanks and Regards,
Veena
VeenaJ_Intel
  • Project Files
Thanks and Regards,
Veena
Lamine06F
Your explanation was important for me to progress. Thank and have a long life
VeenaJ_Intel
Thanks and glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Thanks and Regards,
Veena
