Intel® MPI Library
Mpirun with intel debugger
cfduser
I am trying to use intel debugger with mpich 2. I issue the following:
mpirun -idb=gdb -np 2 ./a.out
and get the following message
invalid "local" arg: -idb=gdb
As per the instructions I found online, I have set the $IDB_HOME to where the debugger is "/opt/intel/idbe/9.1.040/bin/" and also copied mpirun_dbg.idb into the directory where mpirun is located "/usr/local/mpich2-1.0.3-install/bin/mpirun"
Any clues as to the source of the problem?
Thanks!
cfduser
I tried the following: mpirun -np 2 idb -parallel ./a.out
and got the following message.
Intel Debugger for Intel EM64T -based Applications, Version 9.1-25, Build 20060928
Reading symbolic information from /home/anup/a.out...done
Assertion failed: falsesrc/appl/procs/paReading symbolic information from /home/cfduser/a.out...rallel/parallelSupport.C338
This is an unexpected condition and may indicate the presence of a defect.
If you wish to report this, please include the stack trace that follows./opt/intel/idbe/9.1.040/bin/idb-e(_ZN15IDBAssertFailed3runEPKcS1_j+0x11) [0xcc24b1]
/opt/intel/idbe/9.1.040/bin/idb-e(_ZN14DTLU_namespace12assertFailedEPKcS1_j+0x27) [0xf56e77]
/opt/intel/idbe/9.1.040/bin/idb-e(_Z19makeParallelSessionv+0x27e) [0xe7fece]
/opt/intel/idbe/9.1.040/bin/idb-e(_Z15decladebug_initiPPKcS1_+0x12eb) [0xcbf953]
/opt/intel/idbe/9.1.040/bin/idb-e(_Z7idbMainiPPKcS1_+0x427) [0xcc0faf]
/opt/intel/idbe/9.1.040/bin/idb-e(main+0x3d) [0xbba01d]
/lib64/tls/libc.so.6(__libc_start_main+0xdb) [0x3714a1c3fb]
/opt/intel/idbe/9.1.040/bin/idb-e(_ZStlsISt11char_traitsIcEERSt13basic_ostreamIcT_ES5_c+0x7a) [0x7e6c6a]
Intel Debugger for Intel EM64T -based Applications, Version 9.1-25 caught signal "Aborted" (6).
If you wish to report this, please include the stack t/lib64/tls/libc.so.6 [0x3714a2e2b0]
/lib64/tls/libc.so.6(gsignal+0x3d) [0x3714a2e21d]
/lib64/tls/libc.so.6(abort+0xfe) [0x3714a2fa1e]
/usr/lib64/libstdc++.so.5 [0x2a95627146]
r/usr/lib64/libstdc++.so.5 [0x2a95627183]
/usr/lib64/libstdc++.so.5 [0x2a956272a3]
/opt/intel/idbe/9.1.040/bin/idb-e(deb_assert+0x89) [0xce0501]
ace that follows.
Assertion failed: falsesrc/appl/procs/parallel/parallelSupport.C338
This done
is an un/opt/intel/idbe/9.1.040/bin/idb-e(_ZN15IDBAssertFailed3runEPKcS1_j+0x11) [0xcc24b1]
e/opt/intel/idbe/9.1.040/bin/idb-e(_ZN14DTLU_namespace12assertFailedEPKcS1_j+0x27) [0xf56e77]
