Intel® MPI Library
2272 Discussions
NUC11 模块在存在BiOS升级时,提示AC电源未插入的提示,导致不能升级
与我狂奔
NUC11 模块在存在BiOS升级时,提示AC电源未插入的提示,导致不能升级 并且在关机后,风扇一直不停止转动,屏幕显示继续进行,在ubuntu系统,显示reboot:shutdown
VarshaS_Intel
We only provide support in English. I have translated your question. Please find the below question:
When the nuc11 module is upgraded, it prompts that the ac power supply is not plugged in, resulting in the inability to upgrade
"Nuc11 module in the presence of bios upgrade, prompt ac power supply is not plugged in the prompt, resulting in can not upgrade and after shutdown, the fan has not stopped rotating, the screen display continues, in the ubuntu system, showing reboot:shutdown"
Does this reflect your question correctly? Let us know so that we could redirect this issue to the right forum for better assistance.
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. Could you please provide an update on your issue?
Thanks & Regards,
Varsha
VarshaS_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks & Regards,
Varsha
