Intel® MPI Library
2284 Discussions
PETSc 3.8 build: internal error: 0_76
4f0drlp7eyj3
I'm attempting a PETSc 3.8 build with Intel Parallel Studio 2017.0.5. The build fails without much information, but it appears to be an internal compiler error.
Some key output:
/home/cchang/Packages/petsc-3.8/src/vec/is/sf/impls/basic/sfbasic.c(528): (col. 1) remark: FetchAndInsert__blocktype_int_4_1 has been targeted for automatic cpu dispatch
": internal error: 0_76
compilation aborted for /home/cchang/Packages/petsc-3.8/src/vec/is/sf/impls/basic/sfbasic.c (code 4)
gmake[2]: *** [impi-intel/obj/src/vec/is/sf/impls/basic/sfbasic.o] Error 4
Could you tell me what this error 0_76 is? I can provide log files or environment info if these will help.
Chris
