Intel® MPI Library
execvp error
gadelha__alexandre
Gentlemen, could you please help with an issue?
I´m using intel compiler ifort version 18.0.2 and intel mpi version 2018.2.199 in a attempt to run WRF model on HPE (former SGI) ICE X machine.
wrfoperador@dpns31:~> ifort -v
wrfoperador@dpns31:~> mpirun -V
Intel(R) MPI Library for Linux* OS, Version 2018 Update 2 Build 20180125 (id: 18157)
Copyright 2003-2018 Intel Corporation.
When I run the executable I receive the following message:
/opt/intel/intel_2018/compilers_and_libraries_2018.2.199/linux/mpi/intel64/bin/mpirun r1i1n0 12 /home/wrfoperador/wrf/wrf_metarea5/WPS/geogrid.exe
[proxy:0:0@dpns31] HYDU_create_process (../../utils/launch/launch.c:825): execvp error on file r1i1n0 (No such file or directory)
Could you help me to solve this problem?
Thanks for your attention. I´m looking forward to your reply.
gadelha__alexandre
Hi everybody, issue SOLVED!
I found the problem. Actually I use to use the SGI MPI (MPT) and with that I only needed to write the following:
mpirun r1i2n0 12 ./geogrid.exe
but since I´ve compiled with intel mpi now I need to set:
mpirun -host r1i2n0 -np 12 ./geogrid.exe
Now I need to know how to set multiples nodes!!!!!
Living and learning.
